03-09-2017, 09:37 AM | #1 |
lincoln v-12 cam
cant seem to find much info on this.want to do a mild built on a 41 linc v-12.how do they respond to a cam ?done quite a few v-12 but only stock.
03-09-2017, 10:08 AM | #2 |
Re: lincoln v-12 cam
Check with the people at H&H Flatheads
03-09-2017, 10:19 AM | #3 |
If for street they can't get out of their own way with a performance cam.
03-09-2017, 10:22 AM | #4 |
I've always wanted to run an L-100 in a Lincoln V12, However the cam needs some compression to preform well in a V8. But the sound would be in-creadacle.
03-09-2017, 10:22 AM | #5 |
I think this is the book you need...I'll have to check at home to be sure:
Ocee Ritch, the Lincoln Continental...if that's the right book (fairly easy to find online) it has a set of dyno tests on a mildly hopped H V-12 and even tosses in a reprint of the Ford overhaul book. |
03-09-2017, 11:07 AM | #6 |
