11-16-2016, 07:40 PM | #1 |
Name of item please
Anyone know what this contraption is called? Also, should the rod on the top right be bent?
Thanks. |
11-16-2016, 07:48 PM | #2 |
Re: Name of item please
Not that I have seen a real, live one but I think that is the gizmo that goes on the back of the block to work the accelerator on a LHD car. I've only noticed them in pictures of the engine. We use something vaguely similar but much heavier to operate the starter.
11-16-2016, 07:55 PM | #3 |
It is an accelerator pedal mover acrosser. for want of not knowing the factory term.
It looks like a left hand drive assembly, but something just doesn't look quite right . Maybe it is just the way the pic is taken, but wonder if it has been dismantled and put back together wrong ? |
11-16-2016, 07:57 PM | #4 |
Yep, that does now look like a right hand drive starter mover acrosser after Synchro mentions it.
Although the bent rod on the left makes it look like an accelerator rod throttle actuator. A starter button would not need that . |
11-16-2016, 08:03 PM | #5 |
If that is what it turns out to be, I want it! I've had to fabricate a couple of them - fiddly.
11-16-2016, 08:06 PM | #6 |
Bob |
11-16-2016, 08:08 PM | #7 |
It is an early 28 accelerator assembly. It attaches to the back side of the block, at the top. It has nothing to do with the starter.
11-16-2016, 08:09 PM | #8 |
Bob C. is a faster typist than I.
11-16-2016, 08:09 PM | #9 |
On closer inspection, it's not a starter mover acrosser. I'm back to throttle mover acrosser.
11-16-2016, 08:27 PM | #10 |
Thanks to all. Forever4 nailed it with the Ford Garage reference. It has the same bend in the top rod. The car is a LHD May 1928 Tudor. The engine is being rebuilt, so I thought it would a good time to clean up, what turned out to be, the Throttle Control Assembly. Great site.
11-16-2016, 09:14 PM | #11 | |
Larry |
11-16-2016, 09:34 PM | #12 |
Also notice that the throttle linkage has two oil holes that should get oiled a few times a year. Also oil the distributor often by filling the oil tube to the top.
11-16-2016, 11:04 PM | #13 |
Any one need I have a box full , some earl some later , all lhd ones , Derek on the shaky island
11-17-2016, 03:22 AM | #14 |
This photo has the RHD starter one. I think the pedal breaks off and they get chucked and replaced by a solenoid and button. I think I've only come across one good one. The gas pedal is a bit harder to replace with fly by wire. |
11-17-2016, 07:46 AM | #15 | |
On the right side frame rail at the bottom of the picture, what is the bracket bolted to the top of the rail? |
11-17-2016, 10:23 AM | #16 | |
11-17-2016, 10:30 AM | #17 |
BOY, there's LOTS of strange stuff on a RHD! The pic makes you think you're having a confusing DREAM!!!
Bill W.
11-17-2016, 11:47 AM | #18 | |
Bob |
11-17-2016, 12:20 PM | #19 |
I can't imagine getting my big feet to and from that accelerator pedal in any safe amount of time.
11-17-2016, 01:16 PM | #20 |
Wow. How come those guys on the bottom of the world always put everything in backwards and upside down?
But then I guess we DO learn something every day, eh? |
