10-26-2016, 05:53 AM | #1 |
mini starter opinions
hello, needing a new starter on my 272 ive found these on ebay anyone used and they fit a 56 272 i checked compatability and says no but they rarley do eh EARLY FORD HIGH TORQUE MINI RACE STARTER 1956 - 1964 they remanufactured nippo denso says done in utah
10-26-2016, 08:17 PM | #2 |
Re: mini starter opinions
I have an Auto Electric Services mini starter in my 54 (312 eng.) Great unit, been on the car over ten years with zero problems.
www.autoelec.com
10-26-2016, 11:10 PM | #3 |
many thanks for link! appreciate
10-27-2016, 12:57 PM | #4 |
have messaged them, awaiting reply
10-28-2016, 03:25 PM | #5 |
dont think they interested,
10-29-2016, 08:40 AM | #6 |
10-29-2016, 10:32 AM | #7 |
MAKES SENSE APPRECIATE ! getting over ruptured bicep surgery so gathering bits together almost as good as fitting them lol
11-04-2016, 03:15 PM | #8 |
heres mine, it look same as all other y block starters? ben told they do vary
11-10-2016, 08:03 PM | #9 | |
I bought and installed the same mini starter as you have when I was restoring my 55 292 FMX setup. Much easier to bolt up but I didn't like that when it was in situ the only support the starter has is the two ears that bolt it to the bell housing. It is only an aluminium baseplate on the starter. The majority of the baseplate is smaller than the opening in the bell housing.
I changed it back to the original starter and have put the mini back on the shelf. When and if the original fails I may reinstall it. I just didn't trust it to last the distance.
Rick West Australia 1958 Ford Mainline Utility, 1955 Ford Tudor Sedan Quote:
11-11-2016, 12:16 PM | #10 |
many thanks ive ordered one as mine stuft it somtimes works then not, ive had it out cleaned it but it just shot,yes going from 3 to 2 mountings i agree but its $hit or bust for me, i also ordered new ring gear but trying starter first!
11-14-2016, 07:14 PM | #11 | |
The ring gear may be alright with the mini starter as they work on the front edge of the ring gear unlike the original.
