10-15-2016, 06:37 AM | #1 |
1935 horns
I'm wondering if someone can help me and post up a clear close up picture of the inside of a horn from 1935. I went to change the wiring on the horns on my car to new cloth covered wiring but when I opened them up they were a bit of a mess inside and at some point in the past someone has added plastic covered wiring and then soldered the wiring to the connections inside the horns but there is also other wiring inside the horns soldered together. I have no idea what ite meant to be like inside the horns or how the wiring is meant to be connected.
I have also changed my car to 12 -earth. How will my horns cope with this? Can I get them changed to 12v or would a voltage dropped work with them? No idea where I wild put a voltage dropper though given the location of the wiring and the size of the horns. I've looked in my 35/36 book from the early ford club but it doesn't cover what I'm looking for. Last edited by weemark; 10-15-2016 at 06:42 AM. |
10-15-2016, 08:02 AM | #2 |
Re: 1935 horns
There have been a number of past threads on this subject (6v to 12v on horns).
10-15-2016, 08:22 AM | #3 |
Re: 1935 horns
The internal wiring of the horns is shown on Fords 1935 wiring diagram. It is very basic. The internal capacitor is wired across the points. The capacitor helps reduce arcing on the points. One side of the coil goes to one side of the points and the second wire from the coil goes to one of the terminal blocks. The other side of the points with just one capacitor wire has a second wire to the second terminal block.
10-15-2016, 09:08 AM | #4 |
Re: 1935 horns
Here's the diagram Terry is referring to. The first one is from the 35 wiring diagram and the second one is from the 36 wiring diagram (very similar). I have no idea what year the horn adjustment figure is, not sure if it helps or just adds confusion!
10-15-2016, 09:08 AM | #5 |
Re: 1935 horns
Mark, I can post or email you a picture of the horn on my original 35 fordor with the domed cover removed when I get back home from a trip.
10-15-2016, 01:12 PM | #6 | |
Re: 1935 horns
here are a couple of pics, as you can see all the wires are all soldered onto connections, the wires to the capacitor have worn through their outer covering which I need to address as well. can I replace the capacitor if needed? what holds the wires onto the points - I assume its not meant to be solder... I think the new wires I have use bullets on the end of them to connect to the horn but I cant see connections of this type in my horns? again I don't believe it should be solder. Last edited by weemark; 10-15-2016 at 03:02 PM. |
10-15-2016, 03:28 PM | #7 |
Re: 1935 horns
Do you recognize the components in the posted photos? There is the coil, points and a capacitor. The points are mounted to the top of the coil and the capacitor is the black cylinder. If it is the same horn components as the 35 diagram shows, one wire would connect to the coil one side of the coil (input) and the output side of the coil connects to one side of the points and one side of the capacitor. The second wire connects to the other side of both the points and capacitor.
The White wire appears to connect to the top side of the points and one end of the capacitor. So the Blue/Red wire must connect to the input side of the coil. The Blue/Red wire would correspond to the Yellow wire in the diagram. The White wire corresponds to the Black wire. Last edited by JSeery; 10-15-2016 at 03:39 PM. |
10-15-2016, 04:01 PM | #8 |
Re: 1935 horns
Jseery, yes I recognise all the components and understand how it should be done now.
The White wire is soldered to a connction which has 2 wires soldered onto it also, one wire goes to the top of the points, the other wire goes to the capacitor. The blue/red wire is soldered to A connection and soldered to it is a black wire which goes under the points and to the bottom side of the points, there is also a second wire on the bottom side of the points which connects to the other side of the capacitor. When I hold the new loom in place it's obvious what wires go to what connections but I still can't see how I would connect the bullet connectors to the horn. Should the wires to the capacitor be connected via a small screw type connector, a bullet connector or should they be soldered on? Should the wires to the points be connected via a small screw so they can be removed or should they be soldered on? |
10-15-2016, 04:06 PM | #9 |
Re: 1935 horns
Where the current wires are soldered "may" have been clips for the bullet connects, I have no idea. One way to connect to new wires (if you don't want to solder them directly as they now are) would be to solder some short pieces of wire in place with bullet connectors on them and use the original style couplers.
10-15-2016, 04:16 PM | #10 |
Re: 1935 horns
Yes I could solder pieces on to accept the new loom. I didnt want to just crack on and do something that isn't right hence the reason I asked for a picture of someone who has one that is right. I would rather have a picture of what should be there then I can start to address the issues.
From memory the horns werent particularly loud or sounded of a pleasing tone, they were more like a quiet fog horn that was muffled with a pair of socks - if you can imagine a sound like that |
10-15-2016, 04:39 PM | #11 |
Re: 1935 horns
This is a Model A horn but the wire connections are the same.
Bob |
10-15-2016, 04:44 PM | #12 |
Re: 1935 horns
The old Sparton CL4 horns had bullet connectors that used to fit into those clips where the wires are soldered. A previous owner may have had problems with them coming loose. These horns were used from 1933 through 1935 and maybe later on some trucks. They were good units and well worth repairing. I'm sure a new condenser can be fitted and air gap adjusted after cleaning the points. There are right & left versions with different tones but I don't know how to tell one from the other.
10-15-2016, 05:20 PM | #13 |
Re: 1935 horns
10-15-2016, 05:22 PM | #14 | |
Re: 1935 horns
I'm sure the capacitor/ condenser is fine, it's just the outer shield on the wire connected to it is damaged. I could put some heat shrink over the wire to ensure its protected again though. |
10-15-2016, 11:04 PM | #15 |
Re: 1935 horns
Mark, Your 1935 6 volt Sparton horns should not be operated on direct 12 volts. Severe arching across the contacts will burn them out much more quickly and the horns tone will be sadly lacking. A suitable resistor should be fitted in the supply wire to each horn to lower the voltage and current drawn. Resistors are available from MACS part number is 28-62259-1 for a 6 amp draw or experiment and make your own. Also that original capacitor connected across the contacts in each horn to reduce contacts arching would have long ago lost its specifications to do the job properly. Purchase new capacitors from an electronics store or on line. Specs for the capacitor are 400 to 600 volts and .2 mfd. Now some people connect both horns in series instead of the original parallel wiring. This has the effect of reducing the current (amps) going through each horn. But with two sets of contacts of both horns operating in series one tends to effect the operation of the other and so the horns sound somewhat OFF tune and not a good idea at all in my opinion. They were designed to operate on 6 volts to produce a nice sound and tone and any variation on this is out of spec. Regards, Kevin.
10-15-2016, 11:42 PM | #16 |
Re: 1935 horns
On the lower picture were the blue wire is soldered the bullet goes at right angles to that you can see the square hole in the insulator block .it contacts the brass that's there .
10-16-2016, 01:03 AM | #17 |
Re: 1935 horns
Koates is correct in saying that you should not operate these horns on 12 volts. I respect his knowledge as he is a very experienced auto electrician. That said, I have operated my 35 Fordor on 12 volts for the past twenty five years, and the horns still work! No resistors- original 6 volt cloth braided wiring looms.
01-04-2021, 07:32 PM | #18 |
Re: 1935 horns
I am working on a '35 that has been converted to 12 volts. First off, I did not do the wiring conversion. This is a project car in a shop and the person that installed the wiring is long gone. It is an American Autowire HWY 15 system. I have verified that the horn switch on the wheel activates the relay in the fuse block and sends current to the horn.
It has the original horn which does not work. I did apply 12 volts to it and nothing happened. I understand that it should not be operated with 12 volts now. The picure with the dome removed shows how the previous person connected the horn. The green wire is the hot. When testing continuity between the two studs, it showed to be an open circuit. After much patience and cursing, I was able to remove the screw holding the two halves of the horn together. It seems as though the stud to which the ground wire was attached to (circled in red) goes to nothing. So, how is it supposed to work? The other stud has continuity to the solder connection -shown with yellow line. Maybe I am not understanding but, the stud the ground was connected to should have continuity to something. Also, just where is the capacitor? I do not see it at all. |
02-01-2021, 10:25 AM | #19 |
Re: 1935 horns
I could use a picture too please. I have a single CL-4. Thank you in advance.
02-01-2021, 10:55 AM | #20 |
Re: 1935 horns
Hello everyone! New member here. Told about this site by a very helpful guy.
I need help with what I believe is a Sparton CL-4 deluxe. I tried uploading a picture of it 6 times to no avail. Could someone help with the following please: 1) a picture of how the wires are connected under the bell and 2) where can I purchase the bracket and screw that the bell attaches to? Wiring too possibly. I've sourced a bell and external mounting bracket. The single horn I have is a 12 volt horn. I know this because I hooked it up to a 6 volt battery (from my 48 Nash) and nothing. I then hooked it up to a power supply that goes from 0 volts to 20 volts and at 12 volts it honks (after I cleaned contacts,etc.), but again at 6 volts nothing. Thank you for any help. Last edited by smittyj23; 02-01-2021 at 11:24 AM. Reason: Add more information. |
