07-04-2016, 06:42 PM | #1 |
Loose shock arm
The right rear shock arm continues to be loose even tho I have tightened the securing bolt. I'm thinking that I can loosen the bolt and slip a rod bearings him in the gap and snug things up without having to remove the wheel and then the shock assembly.
07-04-2016, 06:48 PM | #2 |
Re: Loose shock arm
I have seen a piece of a soda can used as a shim,,, imagination
07-04-2016, 07:38 PM | #3 |
Re: Loose shock arm
If you don't have another shock arm. I have seen where a die grinder was used to remove a little material at the slot. You have to remove the bolt first.
07-04-2016, 10:17 PM | #4 |
Re: Loose shock arm
I shimmed 3 of the 4 sides of the shock's stud using thin shims for the rod bearings. It is tight now
07-05-2016, 01:01 AM | #5 |
Registered User
Re: Loose shock arm
some of the earlier shocks have a smaller shaft
07-06-2016, 08:47 PM | #6 |
Re: Loose shock arm
07-08-2016, 07:17 AM | #7 |
Re: Loose shock arm
The steering drag link, the shock arms and rear brake arms are all of the same design, and all need occasional tightening.
Bob Bidonde |
07-08-2016, 08:57 AM | #8 |
Re: Loose shock arm
07-09-2016, 09:24 PM | #9 |
Re: Loose shock arm
Two short trips and the shims are still in place.
