06-30-2016, 02:11 PM | #1 |
1936 Ford Coupe door Lock
What connects the key lock to the Latch. Looks like I am missing something?? Thanks !
06-30-2016, 02:31 PM | #2 |
Re: 1936 Ford Coupe door Lock
The photo below is not a 35-36 but is a 33. You can see the small square hole for the square shaft out of the door key cylinder when the shaft rotates the receiver the receiver sends a lock bolt up to the mechanism. This causes the mechanism to lock the out side door handle from rotating. The same is true of the 36 door latch mechanism.
07-01-2016, 05:05 AM | #3 |
for your car, contact Phil Migliori in NY. Send a private message to him. His handle is 32Phil. Also, bear in mind that different body styles take different length passenger door lock shafts. If you have the 35/36 resto guide, there is a list of the different requirements in there. Peter |
