05-02-2016, 06:34 PM | #1 |
8BA Question
What's the norm for marking your valves after seating them in new sleeves?? Is 1 thru 4 on the passenger side by the distributor or the drivers side??
05-02-2016, 06:49 PM | #2 |
Re: 8BA Question
Ford cylinders are numbered front to back starting with the passenger front cylinder as one. The passenger rear cylinder is 4. The driver front cylinder is 5 and the driver rear cylinder is 8.
05-02-2016, 07:56 PM | #3 |
Re: 8BA Question
That makes sense. Thank you.
05-02-2016, 09:28 PM | #4 |
Re: 8BA Question
V8 or V6 engine blocks will have one side @ one inch ahead of the other due to the rod connections to the crank.
Bruce
Works good Lasts long time |
05-03-2016, 07:21 AM | #5 |
Re: 8BA Question
The reason I ask is that some machine shops will mark the numbers in the order of the cylinders (front to back). So, it is important to know what the machine shop did. |
