03-05-2016, 08:53 AM | #1 |
Removing Overspray From Tires
I'm working on the new truck and the previous owner painted the wheels and very wisely masked the tires. However, the mask was a bit too small and the tires have red overspray on them. Are there any easy way to remove this. I'm not sure of the type of paint, but I hesitate to use too much physical force and leave heavy scratches on the rubber...
Frank |
03-05-2016, 09:27 AM | #2 |
Re: Removing Overspray From Tires
Lacquer thinner has always worked well for me.
Getting next to the rim might need some cloth stretched over a screw driver or a thin pc of wood . |
03-05-2016, 09:54 AM | #3 |
I would try WD-40 , it works well for over spray on my glasses when I forget to put on an old pair , also used it on other things for over spray .
03-05-2016, 10:02 AM | #4 |
i worked in a body shop in high school, we would use lacquer thinner
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
03-05-2016, 10:36 AM | #5 |
Acytone will remove paint.
03-05-2016, 10:44 AM | #6 |
Marshall |
03-05-2016, 11:04 AM | #7 |
Take it to a coin operated car wash and pressure wash them from a short distance away. Wayne
03-05-2016, 04:34 PM | #8 |
I will try these and report back on my success. thanks.
Frank |
03-05-2016, 06:36 PM | #9 |
ive used a scotch brite pad and some wesleys bleach white or other tire CLEANER not shine.
1929 Model AA - Need long splash aprons! |
03-05-2016, 09:11 PM | #10 |
clean rags and acetone unless the paint is catalized urethane.
03-05-2016, 10:02 PM | #11 |
Just use some cheap flat black spray paint to cover the overspray. It will flake off later, taking the overspray with it.
03-05-2016, 10:42 PM | #12 |
I used Polystrippa followed up with black leather dye.
03-05-2016, 11:19 PM | #13 |
i have noticed this too
03-06-2016, 06:37 AM | #14 |
03-06-2016, 07:05 AM | #15 |
oooo steel wool with cleaner
03-06-2016, 08:16 AM | #16 |
Lacquer thinner is still your best bet !!!!
03-06-2016, 01:29 PM | #17 |
I just tell the wife to get that off there. I don't know what she uses, but it is very clean.
