Old 01-25-2016, 09:34 PM   #1
j32
Default ignition coils
Hi , I just wanted to ask a question about coils. Some experts say to use the
Bosch coil with the internal resistor if your using a point system, then the same experts post a reply saying that they like to use a 1.5 ohm coil with a ballast resistor . The question , does it matter which method you use , won't the outcome be the same , or am I missing something. We are talking about points not electronic ignition.
Thank You
j32 is offline   Reply With Quote
Old 01-25-2016, 09:56 PM   #2
JSeery
JSeery's Avatar
Default Re: ignition coils
Shouldn't matter, but I think Bubba recommends the Blue Bosch coils. He has posted several times with recommendations. Also, might take a look at his new site, he is posting a lot of information on it.
