01-05-2016, 07:01 AM | #1 |
Oil drain plug gaskets
I need to get oil drain plug gaskets (1 to 12) for my 39. A very cheap item but I'm finding suppliers either out of stock or shipping/handling costs make it not worth while.
Anyone on here have or find any other gaskets or O rings that work? Or have any suggestions? Thanks Andy |
01-05-2016, 08:17 AM | #2 |
Re: Oil drain plug gaskets
Last time I needed one I found that most Auto parts stores have a selection of gaskets to choose from either copper to nylon. Chose and installed a nylon one and it has worked as expected.
01-05-2016, 09:42 AM | #3 |
I usually make my own ring gaskets, like you need, if I can't easily find them pre made in the material and diameter I need or want. I have a good supply of sheet stock gasket material in fiber, copper, brass, nylon, etc., in various thicknesses. Have made gasket cutters/punches in many different diameters using thin wall steel pipe/tubing with one end ground sharp. I don't normally buy any of the tubing required to make these cutters, I mainly use different diameter circular items laying around the shop, i.e., exhaust pipe, worn out hole saws, heavy wall thickness cans, etc., to make inexpensive cutters/punches.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 01-05-2016 at 11:11 PM. |
01-05-2016, 10:55 AM | #4 |
Hydraulic supply dealers (i.e., a Parker dealer) sell all kinds of aluminum washers with a bonded rubber seal on the ID. They work great on all kinds of situations where you have imperfect surfaces. Cheap too.
'52 F-1, EAB flathead |
01-05-2016, 11:01 AM | #5 |
Years ago on a family trip I noticed oil dripping from my pan in a rest area two hundred miles after leaving an oil change 'quick-lube' joint. No gasket on the drain plug....aaargh. Unscrewed plug two turns and wrapped it with about 10 or 15 turns of dental floss, tightened 'er back up. It never leaked a drop. I did it again last week on a 59ab because I had no gasket here. I prefer the 'waxed'.
01-05-2016, 11:03 AM | #6 |
01-05-2016, 11:05 AM | #7 | |
01-05-2016, 11:12 AM | #8 | |
Adileo, sorry I don't have a number for you, just measure your bolt.
01-05-2016, 03:47 PM | #9 |
01-05-2016, 07:53 PM | #10 |
I have several gaskets for oil drain plug. They are for my 42 and up. Don't know the dia. off hand and it's too cold to go to garage (10 degrees) out. Let me know measurement.
01-05-2016, 08:16 PM | #11 |
Thanks - 1.5 drain hole. I'm also searching online
01-05-2016, 09:11 PM | #12 |
Take the plug with you and go to NAPA or any other parts store.
01-05-2016, 10:57 PM | #13 |
Or drug store. You only need 'mint' if you run synthetic oil.....
01-06-2016, 07:14 AM | #14 |
Thanks guys. Lazy Online search washed out. I appreciate the good adivise to go local and that's what I'll do.
