12-27-2015, 07:36 PM | #1 |
Model A won't start
Ugh, Last time I started my Model A was a little over a week ago. We've been having a pretty warm winter here in Virginia. Went out to start the car and it would not start. Not a battery issue. . .plenty of current. When I step on the starter, nothing at all. Could it possibly be something with the humidity . . .condensation on any of the contacts? Has anyone dealt with this is the past? Any help would be appreciate.
12-27-2015, 07:40 PM | #2 |
Re: Model A won't start
Is the engine cranking / turning over or not?
12-27-2015, 07:52 PM | #3 |
It is warm here in SW VA as well, if you have jumper cables try grounding a starter bolt to the frame somewhere and see if it is a ground problem. I have had problems with that and finally ran a wire from one of the bolts to the frame which let the starter turn faster, I don't have engine splash pans which tend to do the same thing depending on how much paint is on things.
12-27-2015, 08:17 PM | #4 |
How do you know you 'have plenty of current' ? With that statement I'll assume the lights work.
If that's the case I'd first look at the start switch. Its not hard to remove and check/clean it.[ From your statement the starter doesn't work at all ? ] If the lights/etc don't work, then I'll go back to the first question. Have you checked for a ground problem by using a jumper cable from battery to trans/engine ? Last edited by Patrick L.; 12-27-2015 at 08:49 PM. |
12-27-2015, 08:28 PM | #5 |
Check the simple stuff first I am sure it will be an easy fix old just needing some attention
12-27-2015, 08:35 PM | #6 |
12-27-2015, 08:48 PM | #7 |
Not cranking or turning!
12-27-2015, 08:49 PM | #8 |
Lights work. . .horn works. . .haven't tried the jumper recommendation
12-27-2015, 08:50 PM | #9 |
Thanks. . .more to follow tomorrow or tuesday . . .
12-27-2015, 08:59 PM | #10 |
If you have a volt meter you can check the battery voltage as well as the voltage to the starter... The frame to batt cable connection is also important to be clean... Sounds like maybe your batt maybe low. Start it with the hand crank that always fun
12-27-2015, 09:37 PM | #11 |
12-27-2015, 10:18 PM | #12 |
Could be a number of problems from a bad battery cable, poor ground, or just a bendix (starter) stuck in the flywheel. Put the car in high gear and rock it back and forth. If it is stuck you may actually hear the bendix retract. Of course the battery cables and associated connections along with the starter switch as the guys have said can all be at issue as well.
Check it out and lets us know. Larry Shepard |
12-27-2015, 10:18 PM | #13 |
Is your starter locked? See if it will turn with the crookedy Krank.
Bill W.
12-27-2015, 10:23 PM | #14 |
YES what Larry and POP said... a stuck bendix is a good possibility
12-27-2015, 10:24 PM | #15 |
Put on the lights and hit the starter. if the lights do not dim, it is a connection or starter rod / switch / cable problem. If they go to very dim, the electrical system is at least involved to the starter and a mechanical problem is more likely.
12-27-2015, 10:29 PM | #16 |
Sounds like a low battery... take it out, clean all contacts and charge it... for a day or so... I had a 2A/6V trickle charge which you'd thik would do a better job but I grabbed a 6A/6V from from harbor fright and charged it for 2 days.. Battery has been great for the past month with only 3 driving trips. If you not have a SG cell tester, they are handy...
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
12-27-2015, 11:45 PM | #17 |
My vote stuck bendix.
Turn on the headlights. Have someone look at the lights as you depress the starter Do the light dim? - yes, the bendix is stuck Do the light dim? - no, the problem is with the starter or switch. Something is open or not making connection.
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 12-28-2015 at 03:16 AM. |
12-28-2015, 06:55 AM | #18 |
Yep, starter stuck, good possibility. Didn't think of that. Good call.
High gear and rock it. |
12-28-2015, 07:31 AM | #19 |
A low or shorted battery can also make the lights dim when pushing the starter button
12-28-2015, 10:27 AM | #20 | |
Lay the inductive ammeter across the starter cable and read the draw while pushing the starter switch. If it's low (like 100 amps or less) then you have a poor connection or low battery. If the meter reads high (like 200 or more amps) then the starter is shorted or stuck. |
