12-25-2015, 01:59 PM | #1 |
Removing Pilot Bearing, simple hydrologics...bread!
This worked for me. I packed the pilot bearing hole with bread and pushed/tapped it out using a 7/16 nut driver and a lead mallet. It popped right out. Note: if it would not of come out easily I was prepared to buy the right tool, but it tapped out with little force from the lead mallet and nut driver combination,
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. |
12-25-2015, 02:04 PM | #2 |
Re: Removing Pilot Bearing, simple hydrologics...bread!
Packing it with grease, then tapping the dummy pilot in also works sometimes.. Never tried white bread..
12-25-2015, 02:07 PM | #3 |
I am proud on how it came, but what is the best way to tap it back in?
Paul
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. Last edited by 30ccpickup; 12-25-2015 at 02:08 PM. Reason: Spelling as always.... |
12-25-2015, 02:12 PM | #4 |
I use a hammer and a large socket, small extension that fits the outer circumference. Don't hit on any of the rotating parts if your using a roller bearing
12-25-2015, 02:17 PM | #5 |
Select a socket having the same diameter as the outer bearing race. Place the pilot bearing in the flywheel. Place the socket against the outer bearing race matching the circumference of the bearing. Tap the socket with a hammer or mallet until you see the bearing flush with the flywheel or you hear a "thunk", which ever comes first.
12-25-2015, 02:44 PM | #6 |
12-25-2015, 03:01 PM | #7 |
I wouldn't waste whole wheat bread doing this, but it sounds like a good use for white bread.
I've always used grease to remove them. BTW, I noticed the safety wire and pin retaining washer is missing. |
12-25-2015, 03:02 PM | #8 |
I wonder how raisin bread would work
12-25-2015, 03:08 PM | #9 |
I heard grease gives you the squirts and bread did not. That is why I went with bread.
12-25-2015, 03:23 PM | #10 |
I just looked in my 2015 Snyder's catalog and can't find that flywheel dowel pin retainer plate listed.
If your's is missing you might have to call Bert's for a good used one. |
12-25-2015, 03:26 PM | #11 |
As we all know fully restored means nice paint and put back together however. The reason I have it apart is do to clutch in backwards plus what ever else I find.
12-25-2015, 03:36 PM | #12 |
Mitch , a
You and Tom are good Christmas humor . You can always go to the thrift store and get you choice . Personally I just use the Krw remover and replacer tool. The sockets work ok in a pinch Merry Christmas guys! Larry Shepard |
12-25-2015, 03:41 PM | #13 |
Thanks Tom I will research.
12-25-2015, 03:56 PM | #14 |
Merry Christmas Larry
I have the right tools also. Not KRW though just snappy Last edited by Mitch//pa; 12-25-2015 at 04:02 PM. |
12-25-2015, 04:01 PM | #15 |
When your going to "pound" on something...Bimbo bread works best. breads are all the same, it's just more fun...with a bimbo.
12-25-2015, 04:43 PM | #16 | |
Larry
Good enough.. Isn't. |
12-25-2015, 05:02 PM | #17 | |
Thanks, found.
12-25-2015, 06:18 PM | #18 |
I think most of the vendors will have that retainer. Bratton's has it. #11560
12-25-2015, 11:07 PM | #19 |
I used grease in my 1940 Ford pilot bearing and it blew the outer seal out, then had to use a internal slide puller to remove the bearing. That is the only one that ever done that so grease works good 99% of the time.
12-25-2015, 11:42 PM | #20 |
We have better uses for a loaf of bread...
