11-27-2015, 07:10 PM | #1 |
carburetor on 8ba
11-27-2015, 07:16 PM | #2 |
Re: carburetor on 8ba
Looks like a Holly 94 to me.
Gene |
11-27-2015, 07:21 PM | #3 |
Your '37 should have a Stromberg 97 on it....
11-27-2015, 07:25 PM | #4 |
look on the other side of the float bowl and see if any number/letters are there
8BA 49-53 59 46-48 21 29 late 41-42 91 99 29-41 there were a few other numbers/letters on 53 merc with at trans if it was a holley it would be written on the bowl |
11-27-2015, 08:07 PM | #5 |
Tex,
Your '37 air cleaner should fit the 94. Most likely the diameter of the air cleaner neck on the air horn is worn undersize, happens all the time. I have a bunch of NOS air horns if you are interested. Charlie ny |
11-27-2015, 08:11 PM | #6 |
11-27-2015, 08:18 PM | #7 |
Look at the back of the float bowl, see if it says 94--1--1-3/16 the real big trucks had a big carb CFM, the air horn and choke was bigger. Walt
11-27-2015, 09:18 PM | #8 |
11-28-2015, 05:50 AM | #9 | |
I have one of the big puppy's with the V clamp air horn (truck style air cleaner) and yes the bore of the air horn and the choke butterfly are indeed bigger the a regular 94, but the outside dimension of the air horn, the V shaped clamp part is the same size as my 8RT carb, in other words the stock 8RT air cleaner fits on the big one. The pictured carb is obviously a car style air horn, did these have a bigger outside dimension the the regular 94 car style air horn? Just to muddy the water a bit, I have come across some 94's that have a slightly small air horn outside dimension than standard, a stoke Ford car style air cleaner doesn't fit, and won't clamp on the horn. Never worked out why or where these odd ball ones came from. Martin. |
11-28-2015, 07:41 AM | #10 | |
