Old 10-01-2015, 12:57 PM   #1
Greg out west
Question hard steering
Hi guy's,
Rebuilt my 2 tooth steering box with all new parts...even did needle brg
modification.....Had the steering balls replaced & install the teflon "kit". When I had to move the car to a safe place,,, I was shocked when it steered like a truck
I had a feeling something was going to be wrong as I screwed in the end plug's & could just get the cotter pins in...Then the drag link & tie rod are way too tight.
I read way back that when properly adj, you should be able to "twist" it(rod) with 2 hand's.Mines sure not like that !!
Any idea's whats wrong ?..
Thanks,,,
Greg out West
Greg out west is offline   Reply With Quote
Old 10-01-2015, 02:06 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: hard steering
Are the spindles rubbing on the axle?
I've heard some of the new bearings are thinner than originals, so you may need to use a shim.
Old 10-01-2015, 04:05 PM   #3
rocket1
how did it steer before,disconnect the pitman arm and turn the steering wheel from lock to lock,ok?then it must be at the balls for the drag link and tie rod.
rocket1 is offline   Reply With Quote
Old 10-01-2015, 04:35 PM   #4
Greg out west
Thumbs up Re: hard steering
HI Tom,
I USED THE "T83" TIMKEN AT THE KING PINS THEN USED THE SHIMS TO GET A SNUG FIT MAYBE ..NEXT THING I Can do Is put the old original kit back in & try again Btw,,Thank's to all for the kind word's the other day
God Bless you guy's
GREG Out West
P.S.Do you know what size the the steering ball's..I'll Have to check them when I PULL it apart
Old 10-01-2015, 06:30 PM   #5
1931 flamingo
1931 flamingo's Avatar
How does it turn if you jack the front end up?? Is the Teflon kit assembled correctly?? Did you put some grease in the Teflon kit?? Is there lubricant in the steering box??
Paul in CT
Old 10-01-2015, 11:32 PM   #6
Larry Jenkins
Originally Posted by Greg out west View Post
HI Tom,
God Bless you guy's
GREG Out West
Get a set of 0-1" micrometers; measure the thickness of the original bearing height; then measure the replacements. Add shims to compensate for the difference.
Les Andrews book covers this quite well.
Larry
Larry Jenkins is offline   Reply With Quote
