09-10-2015, 10:56 AM | #1 |
need help with clutch
I need help making a 39 trans. Connect to an 8BA 9.5" clutch..It seams the coller for the through bearing on the 1 3/8 " shaft interferes with fingers on the pressure plate, and the through bearing does not contact the clutch.I read on the H.A.M.B that the only fix was
a 10 or 11" clutch. Kerry at FW clutch says they have sold many of these 9.5" / 1 3/8" Clutch kits for the 8BA conversion so something must work. All advice is greatly appreciated. Thanks |
09-10-2015, 11:18 AM | #2 |
Re: need help with clutch
Someone I know had an 8BA 10.5 rebuilt with shorter early Ford type fingers...that's possibly what Fort Wayne is talking about...?
Existing 8BA stuff: 9.5 You know about that... 10" 8BA This was light duty F1, 8BA heavy duty...can use '46-8 Ford pressure plate to use that flyweel with '39 trans. Not very common. 11" F series...very common, goes right into early Ford, but stiff and heavy '49-53 Merc flywheel using '49-50 Merc pressure plate...another bolt-in but that pressure plate is getting hard to find. There is apparently a modern replacement...? I'd find out about FW, and investigate cost of having whatever wheel you have redrilled for 10" Last edited by Bruce Lancaster; 09-10-2015 at 11:52 AM. |
09-10-2015, 04:12 PM | #3 |
May not be ford. Last edited by George/Maine; 09-11-2015 at 12:11 PM. |
