06-22-2015, 02:47 PM | #1 |
1936 Crack in cylinder head- Help!
A crack has developed in my 1936 Woodie's cylinder head, where the water pump attaches to the cylinder head, (see attached photos).
It's leaking radiator fluid whenever I drive and I am praying I won't have to replace the whole cylinder head. What to do? Can I weld it back together? Is there some miracle epoxy/glue out there? Do I just keep the radiator fluid topped off and live with it? I am a bit of a rookie in repair, but handy with a tool and eager to fix it. Many thanks for any advice... |
06-22-2015, 02:59 PM | #2 |
Re: 1936 Crack in cylinder head- Help!
Tim:
I might have a 35-36 head in the shed if you choose to change it. Let me know and I will take a look. Dave/GreenBay |
06-22-2015, 03:03 PM | #3 |
Try some JB weld on it.
06-22-2015, 03:08 PM | #4 |
You might be able to limp it for a few extra miles by replacing the bolt with a nut and bolt. Maybe a 5/16" bolt will go through.
A skilled welder could probably repair that, but the head would have to come off to enable pre heat and proper weld prep. I would imagine it would be brazed rather than welded. It would probably be easier to find a suitable replacement head. Cast iron heads are often discarded as virtually worthless. Mart. Last edited by Mart; 06-22-2015 at 03:50 PM. |
06-22-2015, 03:44 PM | #5 |
First thing to try as others suggested. Drill it out for a bolt and nut, clean it good and fill with JB weld. JB weld is great stuff.
John |
06-22-2015, 03:47 PM | #6 |
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 06-22-2015 at 08:30 PM. Reason: "suffix" should have been "prefix" |
06-22-2015, 03:59 PM | #7 |
as suggested use a nut and bolt but use a washer on either side to spread the clamping force.
06-22-2015, 04:04 PM | #8 |
Do as suggested , BUT take off water pump clean both mating surfaces & install new gasket using 3M yellow weather strip cement on both surfaces & gasket & you should be good to go !
06-22-2015, 04:28 PM | #9 |
I would be tempted to braze it in place....not to much material to heat up.
Then just new gasket and back on the road... |
06-22-2015, 10:25 PM | #10 |
Don't even have to drill it, just use a longer bolt, one that sticks through enough to put a washer and nut on
06-22-2015, 11:03 PM | #11 |
Timo - I'd weld it, not braze it. Have stick welded these with high nickel content rod.
Ronnie on this site, would TIG or GTAW weld process on this. Do some grinding, drill a hole and you are down the road, without an anxiety attack waiting to happen, wondering about the epoxy you put on. You have a high dollar ride, keep it on the road. Come on out to Woodies on the Wharf this Saturday in Santa Cruz, Ca. and hang with hundreds of your woodie friends.
Henry Ford designed the flathead without the aid of a computer. |
06-23-2015, 06:46 AM | #12 |
These heads are available for not much I believe I have a pair gathering dust.
06-23-2015, 09:46 AM | #13 |
Thanks to all for some thoughtful and helpful tips. I've got enough support from you all to tackle it myself. Love these forums!
06-23-2015, 10:10 PM | #14 |
Tim:
Looked in the shed and I found a 35-36 cast iron head. Pay the shipping and it is yours. Dave/GreenBay |
