06-02-2015, 06:48 PM | #1 |
OT solid copper head gasket quetion
I am not on HAMB so I will ask here. What is the minimum thickness and type of copper used to make a solid copper head gasket? (dead soft?) This will be used for a Chevrolet over head valve conversion using an aluminum adapter plate on a Model T but figured I would have a better chance of getting the info here. I know some guys use the solid copper gaskets on their conversions. I plan on making it myself.
Thanks MarkG |
06-03-2015, 07:26 AM | #2 | |
Re: OT solid copper head gasket quetion
1. Charlie Yapp of Scalded Dog parts used to sell solid copper gaskets. As far as thickness ... from his site. It is not a solid copper gasket but compressed thickness is .042. http://www.secretsofspeed.com/gaskets Flathead - Cylinder Head Gasket $45.95 each IN STOCK Fits Model A and B engines with up to 4" bore. Compression ratio up to 8:1 CR. This is the "BEST" brand head gasket #573-G - carbon and arimid fiber over inner steel core with steel fire rings around the combustion chamber. Coated with a polymer to seal on first run. This type of head gasket is the only head gasket we recommend. It last longer and leaks less. Compresses to about .042". Recommended Torque is 55 foot-pounds. Higher torque settings can warp cylinders. If required, go higher only when used with a Torque Plate. Scalded Dog Speed Parts 3860 Cain Run Rd, Batavia OH 45103, USA . Phone (513) 724-0700, EST. [email protected] 2. Also Bill Stipe installed an OHV modified head on his Model A engine. http://www.specialtymotorcams.com/pa...nversions.html Specialty Motor Cams Stipe Machine Co. Inc N5718 County Road M Plymouth, WI 53073 Phone: 920-467-2895 Fax: 920-467-9700
06-03-2015, 07:51 AM | #3 |
This company might have your answer. http://www.headgasket.com/whoweare.html
06-03-2015, 09:20 AM | #4 |
Thank you. I did do some reading last night and got some information to mull over. Because of how the adapter plate was made using the stock type Chev 4 cylinder head gasket will not work, the fire rings are unsupported on part of the bore.
MarkG To put the Model A into this discussion, I am also doing some valve work on one of Jern Thunderbolt overhead conversions for a Model A. |
06-03-2015, 09:35 AM | #5 |
Can you give me more information on the chevie head on an A engine. I heard of this years ago using a 1920's chevie four head but know nothing else about it. Thanks in advance, Jack
06-03-2015, 09:40 AM | #6 |
V4f |
06-03-2015, 10:38 AM | #7 |
I run .060 Solid Copper Head Gaskets on my Dragster. 296" Supercharged Flathead V8.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
06-03-2015, 11:42 AM | #8 |
I also have used .060 solid copper and asked a few years back about a .125 thick solid copper . It was very expensive. I googled copper head gasket once and found a shop in so ca that would custom fit a solid copper gasket to my head.
06-03-2015, 02:52 PM | #9 |
I have a copper head gasket as a spacer between two B6051-C gaskets. The pistons come up quite high and the head is not undercut for the pistons. The head is a Winfield crows foot. Anyhow, the copper head gasket came from Clark Copper Gasket. http://clarkcopperheadgaskets.com/
They will make gaskets in what ever thickness you need.
1965 Lotus Elan S2 1930 Model A Sport Coupe Last edited by bettlesr; 06-03-2015 at 02:53 PM. Reason: Fat fingers |
06-03-2015, 06:45 PM | #10 |
RE Chevrolet overhead setup, Thunderbolt;
http://jernthunderbolt.com/Model%20A%20.html |
06-04-2015, 07:54 AM | #11 |
I used the chev head one time. I made my own adapter plate. Use .060 soft copper and O ringed the plate for steel wire. Used a gasket from http://jernthunderbolt.com/Model%20A%20.html for the head side.
But was not that happy with the power. The head has a lot of restrictions. In the end I made my own head. |
06-04-2015, 09:50 AM | #12 |
Thanks redmodelt thats what i have been looking for. Jack
06-04-2015, 09:21 PM | #13 |
George;
Nice! Using the Chevrolet head keeps my creative juices flowing because every time I go to do part of the job I have to think how to make it work. |
