Old 05-15-2015, 10:34 PM   #1
afuncar
Default engine noise
I have a noise in my engine, there since day one of new engine, it's a clack or slap noise. Re set lifters no differance still there, removed timing cover to see if spring on cam plunger broken or missing, everything o.k. Noted the seat for cam button was loose fitting sloppy, wandering if that could cause the noise? the noise sometimes gone when I start motor, then becomes more pronounced as it warms up and may go away when fully warmed up. Seems to come from timing gear area, have aluminum timing gear, everything looks o.k.
afuncar is offline   Reply With Quote
Old 05-16-2015, 05:48 AM   #2
beechboy
beechboy's Avatar
Default Re: engine noise
Just a guess, any chance there is a gen, or alt, bearing going out/ When I try to find noises, I use a piece of hose held to my ear to track things down.
beechboy is offline   Reply With Quote
Old 05-16-2015, 06:27 AM   #3
James Rogers
James Rogers's Avatar
Change the gear to a fiber gear or put up with it. Some of the aluminum gears will clik or knock when running. It won't hurt anything but, is annoying.
Old 05-16-2015, 09:19 AM   #4
afuncar
the noise is from timing gear region I've used a stethoscope tool to narrow it down, I think James is correct when I looked nothing appeared to stand out as the cause of noise. Aside from noise it's a good powerful motor. may try a fiber gear. Thanks for help good to have a few opinions.
Old 05-16-2015, 11:06 AM   #5
Jim Brierley
Could also be lifters loose in the block caused by worn block. Cure is oversize lifters and reamed block to fit, or just don't worry about it.
Jim Brierley is offline   Reply With Quote
Old 05-16-2015, 01:03 PM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Minerva's Bronze gear was noisy, gradually quieted down, after about 2,000 miles.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-16-2015, 02:03 PM   #7
afuncar
thanks Bill hopefully mine will too. I have about 1000 miles on it now, I may try a fiber gear.
