04-03-2015, 07:21 PM | #1 |
Spare Tire Bolts
These bolts are supposed to be swedged on to the rear mount tire bracket.
These special bolts have a square shoulder built in to them. The original bolts square shoulder is 1/4"-5/16" in depth. The bolts from Snyders, Brattons, & Macs are only 3/16" and they cannot be swedged. Does anyone know where the correct bolts can be obtained? Thanks. |
04-03-2015, 10:41 PM | #2 |
Re: Spare Tire Bolts
Here in South Florida machine shop rates are about 60.00 an hour, one hour minimum. I went to several figuring it would be easier and faster to have them fix the ball on the shifter, just weld and grind. Was quoted between 120- 150 dollars. Must be cheaper where you live.
04-04-2015, 04:40 AM | #3 |
I found the complete spare mount at a swap meet for $5 about 10 years ago.
04-04-2015, 09:19 AM | #4 |
I appreciate the replies.
Machine shop route too expensive. Have no equip to braze, weld, etc. Tried the only # for A&L in Ct. I could find and it is a non working #. Saw a complete one 4 sale on Ebay but would be $42+ IF I was the only bidder. I will secure the bolts with the rear spare lock nuts. Thank you again. Bob H. |
04-04-2015, 11:33 AM | #5 |
Epoxy?
04-04-2015, 11:37 AM | #6 |
