Old 04-02-2015, 07:05 AM   #1
Hivolt5.0
Hivolt5.0's Avatar
Default 1939 Ford Deluxe Headlight Bucket
I have a question for you guys, I'm rewiring a friend's '39 Ford and was just curious about the headlight buckets. Hopefully this will make sense with the pictures. Is the lip around the opening at the bottom supposed to be folded over like it is? It just looks like it was cut and folded over. Someone in the past used foam rubber to seal the lens to the bucket so I'm not really sure how the stock gasket should work. Thanks in advance for your help.
Hivolt5.0 is offline   Reply With Quote
Old 04-02-2015, 07:59 AM   #2
adileo
adileo's Avatar
Default Re: 1939 Ford Deluxe Headlight Bucket
No pic
adileo is offline   Reply With Quote
Old 04-02-2015, 08:15 AM   #3
Hivolt5.0
Hivolt5.0's Avatar
The pictures are showing up for me....interesting.
Old 04-02-2015, 09:08 AM   #4
40cpe
40cpe's Avatar
I see the pictures, can't help with the question.
40cpe is offline   Reply With Quote
Old 04-02-2015, 09:52 AM   #5
adileo
adileo's Avatar
Weird I still don't see
Old 04-02-2015, 11:40 AM   #6
Fullfendered
Fullfendered's Avatar
adileo, it's your browser, if older version of Explorer update it or install Chrome.
Fullfendered is offline   Reply With Quote
Old 04-02-2015, 12:00 PM   #7
maneri
maneri's Avatar
you can save them bend metal back up then seal a cork or new style rubber gasket to it around the inside edge (some looks removed)
maneri is offline   Reply With Quote
Old 04-02-2015, 01:54 PM   #8
Hivolt5.0
Hivolt5.0's Avatar
Thank you! I'll do as you recommend.
Old 04-02-2015, 03:35 PM   #9
swoopNZ
MEMBER EMERITUS
Occasionally you need to bend that tab to give better alignment for the screw that holds the bottom of the stainless rim PN 91A-13045.
swoopNZ is offline   Reply With Quote
Old 04-02-2015, 11:03 PM   #10
fordor41
fordor41's Avatar
Maybe to let any water drain out.
fordor41 is offline   Reply With Quote
