03-29-2015, 06:05 AM | #1 |
Model B distributor
Are any folks running a Model B distributor? I'm thinking of trying it. Any pros or cons? Comments are appreciated. Thank you.
03-29-2015, 08:47 AM | #2 |
Re: Model B distributor
The model b had a different timing cover because the base timing was different ---
I don't think parts support is as good ---there is a very good condenser for the A that won't burn out ---but it isn't made for the B dist I have one in my Smiths compresser, I had thought it ideal for that use, over 25 years, now I am changing back to stock A along with a right hand drive intake to give me a handy advance lever (the RHD manifold has a nice lever on the top for advance) It's not a full range advance, it's about like starting with the lever 1/2 way and going to full advance, there is no compensation for load, it just adjusts for rpm |
03-29-2015, 11:04 AM | #3 |
I ran one years ago, and it ran fine ... but, points are hard to find and after I ran it on a distributor machine I discarded it. The cam was badly worn so firings were not 90* apart and the advance was uncontrollable. Perhaps if it was in good shape they would be OK?
03-29-2015, 11:21 AM | #4 |
Vince has some good info on his site and Renner's Corner has parts.
http://www.fordgarage.com/pages/bdistributordetails.htm http://www.fordgarage.com/pages/bdistributoradvance.htm http://rennerscorner.com/distributor-rebuilding.html http://rennerscorner.com/distributor.html Bob |
03-29-2015, 01:06 PM | #5 |
Renner's corner has parts as do others. Some cams sold by large distributors are rough but the cams from Renner's seem to be of good quality
03-29-2015, 01:11 PM | #6 |
03-29-2015, 02:08 PM | #7 |
I am running one in my '31 RDPU but it is on a B engine with a B timing cover. Search the archives on how to time using an A timing cover. I would like also to recommend Renner's Corner for parts, rennerscorner.com, (734) 428-8424. If you can't find a high quality Model B condenser it is easy to modify a Model A condenser (be sure to get the high quality Model A condenser). Elongate the mounting hole in the tab and install a short wire from the condenser to the distributor (see picture).
Charlie Stephens |
03-29-2015, 03:57 PM | #8 |
Hey Charlie,
Thanks for the info/picture ! |
