03-15-2015, 06:16 PM | #1 |
Sources for coolant water to get in the oil V8-60
So, yesterday I pulled the dipstick on the '38 coupe and discovered chocolate milk in the oil pan.
Seeking help on the initial thought process. What is the most common source of coolant water getting into the oil gallery? Pulled the plugs to see if any droplets were on any of them. Nope. They look fine. At first my heart sank and I thought about selling the car. But realistically, the V8-60 isn't getting the job done anyways and perhaps this is the trip lever to start looking for a good running full size V8. Anyone got one for me. Need trans also, and the bigger '38 radiator.
He is no fool who gives what he cannot keep, to gain what he cannot lose... Jim Elliott, 1949 http://tonopahpictures.0catch.com |
03-15-2015, 07:55 PM | #2 |
Re: Sources for coolant water to get in the oil V8-60
Is the oil level noticeably up from the coolant? If not, check the crankcase ventilation system for restrictions. Could be condensation in the oil. Change the oil and check it after every use of the car to see how fast it gets contaminated with water. Sounds like you're going to change out the motor anyway.
03-15-2015, 08:38 PM | #3 | |
03-16-2015, 02:02 AM | #4 |
I had the same problem with my 8BA. Over time the oil level would rise, and the oil turn milky. Head gasket was the issue. A Walt Dupont rebuild cured the issue.
03-16-2015, 07:15 AM | #5 |
There are a few areas where water can enter the oil. It happened to me in my 34 Ford with the V8. I could remove a Head to see if that was the problem, but which head, and sometimes, these are hard to remove, plus the expense of new Head Gaskets. Then I got to thinking that one of the Freeze Plugs (we call them Welsh Plugs) could be the problem? So decided that this was the first place to look, so jacked up the front of the 34 and removed the Oil Pan, & sure enough, one of these small Freeze Plugs was leaking. This was a good time to clear out these passages in the Block. After cleaning by pushing a screw driver up and down in the holes, then washed it out with water, I replaced all four of them while I was at it. Made up a new Gasket and replaced the Pan. Replacing a Pan while the Motor is still in the car is not the easiest thing to do, but is much easier than removing the whole motor. Problem Solved. It worked for me. The attached photos show two of these Welsh Plugs and the Sludge that came out of another 34 Block that was removed from the car |
03-16-2015, 09:56 AM | #6 |
03-16-2015, 10:01 AM | #7 |
NOTE: A V8 - 60 does not have these plugs.
mine did. tom |
03-16-2015, 10:13 AM | #8 |
OOPs Forgot about the big one in the middle of the rail.
03-16-2015, 06:31 PM | #9 |
Thanks for all of this. Where is the "middle of the rail" one at. Sorry to sound ignorant but haven't heard that terminology before. Appreciate the help.
03-16-2015, 07:48 PM | #10 |
The rail is basically slang for the bottom outer edge of the block where the oil pan bolts on. About 1/2 way from front to rear is a location for the core plug. There is one on each side and these can rust out and leak coolant.
03-16-2015, 08:07 PM | #11 |
Sweet. Thanks. jg
03-16-2015, 09:27 PM | #12 |
With acold engine---Fill the radiator to the top with water, crank the engine with the ignition off, if the level rises and then bubbles come take off the heads
03-16-2015, 11:26 PM | #13 | |
He is no fool who gives what he cannot keep, to gain what he cannot lose... Jim Elliott, 1949 http://tonopahpictures.0catch.com Last edited by jim galli; 03-16-2015 at 11:31 PM. |
03-17-2015, 01:32 AM | #14 |
I'm no expert but I have a close friend who I would consider to be an expert on the 60-horse V8. The water pumps on a V8 60 are lubed with engine oil through a passage in the front cover. The pumps are pressed or screwed in place so the passages are not visible, but if the seals leak on the pumps the coolant uses those passages to travel into the crankcase. I wouldn't be surprised if rebuilt water pumps cured your problem; you may be getting coolant in your oil through the pumps via leaky seals.
