01-25-2015, 06:20 PM | #1 |
Reproduction Fuel Tanks
Who makes the best for a stock '35?
01-25-2015, 06:39 PM | #2 |
Re: Reproduction Fuel Tanks
I do not know who makes them, but they must be good as I have not been able to sell a very restorable 37 tank. Rod
01-25-2015, 07:00 PM | #3 |
I bought one for my 46 from Tanks inc. Good quality. Here's the link.
http://www.tanksinc.com/index.cfm/pa...=cat/cat83.htm
The sign of a good craftsman is how well they cover up their mistakes. |
01-25-2015, 07:28 PM | #4 |
I too just bought a tank for my 35 pickup from Tank's Inc or Yogi's (same address) good price and service. The only difference I noticed was the filler neck is not threaded like the original. Bob Drakes tanks appear to be more like original.
01-25-2015, 07:35 PM | #5 |
I use Tanks. Just plain easy to deal with. Never had a problem to date.
01-25-2015, 10:20 PM | #6 |
Pat |
01-25-2015, 10:29 PM | #7 |
I got my '33 tank from Bob Drake in 2004. Then the year later they offered the same tank with an anti-backwash flap that was supposed to help stop leaking gas from the filler tube. Oh well! Mine does leak when the tank is full and I am parked slightly up-hill. Only when I top her off though and sometimes I can smell gas easier than the "A" .............
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
01-25-2015, 11:16 PM | #8 |
Thanks to all of you for your suggestions.
10-24-2017, 04:26 PM | #9 |
Have any of you had experience with installing a "Tanks, Inc" tank from underneath? Today I removed my original tank after continuing fuel contamination problems...just plain nasty looking inside. Apparently a prior effort at sealing the tank had failed (would have been done in pre-ethanol-spiked gasoline days), with the result that there's now black goo and rust on every surface. The original came out easily, but I'm concerned about the reports that Bob Drake's tanks won't go in from underneath, and am unsure about that problem with other brands. Also, any experience with the plastic tanks? Any suggestions/thoughts?
10-24-2017, 07:29 PM | #10 |
I replaced the tank in my 1946 Convertible with a Drake tank, very minor issues with the installation from underneath. I am pleased with the result.
10-25-2017, 12:14 AM | #11 |
Drake, nor anyone reproduces a correct 35 tank. The problem being the hydrostatic sending unit. You could use a 36 drake tank if authenticity it not that important. I have used three drake 36 tanks in 35’s and they all fit.
Now the drake 40 tanks do require a effort or at minimum minor trimming |
10-25-2017, 08:00 AM | #12 |
Has anyone used the "tanksinc" fuel sender?
The best way to have a friend is to be a friend. Howdy Doody |
10-25-2017, 09:16 AM | #13 |
I've used the Tanks fuel sender on 4 cars. It's made by VDO. It works to a degree, but is not all that accurate when using the original gauge. It's basically a "guide" as to how much fuel is in the tank. Your best bet is to use a modern sender and the matching gauge under the dash, or put it in the right cowl panel where you can see it from the driver's seat.
11-08-2017, 01:31 AM | #14 |
Just a short follow up on this. I ended up ordering one of Bob Drake’s tanks. It came in 3 days, was beautifully made, and slipped in from below without difficulty. Kudos to Bob and his staff.
11-08-2017, 09:54 AM | #15 |
I have a Tank's in my 35 with a Tanks sending unit and a 36 fuel gage and it works great. I did have to modify the filler neck.
11-08-2017, 10:18 AM | #16 |
Got a tank from Dennis Carpenter for my '39. Perfect fit and flat rate shipping. Stainless tank from Rock Valley, however had one of the baffles in the wrong place, so the float was permanently obstructed.....expensive mistake!!! Gauge registered half full when I ran out of gas at night on a dark road!!!
Dick. |
