01-24-2015, 03:00 PM | #1 |
Is my fan OK?
01-24-2015, 03:12 PM | #2 |
Re: Is my fan OK?
This is my original.
Bob |
01-24-2015, 03:22 PM | #3 |
Re: Is my fan OK?
A picture IS worth a thousand words.
01-24-2015, 03:25 PM | #4 |
Re: Is my fan OK?
the 4 blade fan you have came from Ford as a replacement. It was original on a B engine. While not as easily broken as the original 2 blade A fan, they are old, and they can and do break from metal fatigue. I've been there on a tour when a 4 blade disintegrated on a member's car. Not to mention that with the 4 blade fan, a repair or replacement to the water pump requires removing the radiator. With a 2 blade fan, you can remove the radiator rods and top hose, pull the radiator forward a bit, rotate the 2 blades to horizontal, and remove and replace the pump without removing the radiator.
The reproduction aluminum 2 blade fan has been shown in a Model A Times article to cool better than the 4 blade as well as to be durable and reliable and ( happily) cheaper than the alternatives. I would replace that fan when I had the opportunity if it was on a driver that was driven often. |
01-24-2015, 08:27 PM | #5 | |
Re: Is my fan OK?
Charlie Stephens |
01-24-2015, 08:34 PM | #6 |
Re: Is my fan OK?
The usual mode of failure I've seen for the 4 blade is failure of the rivets. Has anyone had the blade rendered asunder (as in splitting at the rivet holes?) It might be possible to improve one's chances if they replaced the rivets with high strength bolts? Just thinking out loud here. Joe K
Shudda kept the horse. |
01-24-2015, 09:30 PM | #7 | |
Re: Is my fan OK?
He took both fans, had the blades inspected for cracks, and there were none. He replaced the rivets with high strength aircraft bolts with self locking nuts. Both fans are still being used with great success.
01-24-2015, 10:13 PM | #8 |
Re: Is my fan OK?
You may, I say may have stumbled on the one things these old pros all agree on. Two-blade is nearly universally preferred for the reasons sited above. Plus, they look better. Sort of "older".
Forty horses is plenty. |
01-24-2015, 11:27 PM | #9 |
Re: Is my fan OK?
When that four blade becomes a three blade you will probably become a believer. I have had experience with both two and four blade fans in the last couple of years. One cost me a radiator core, the other cost a friend a hood section and hood repaint, plus some straightening of the cooling fins on the radiator and soldering a couple of tubes. For me, not worth the gamble. Aluminum or plastic on mine. JMHO FWIW
01-25-2015, 08:55 AM | #10 | |
Re: Is my fan OK?
As a side note, everyone always says "don't throw anything away". Is this one of those things I can throw away? If it's not safe, I don't see any point in keeping it. Chris |
01-25-2015, 09:03 AM | #11 | |
Re: Is my fan OK?
01-25-2015, 09:10 AM | #12 |
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
Re: Is my fan OK?
I have a two blade aluminum fan to be installed end of March. My four blade fan is cracked. I drive with all fingers crossed and constant Hail Mary's coming from my mouth and I'm not even Catholic. Let's say, the fear of the Four Blade Cracked Fan God was put in me here at the Ford Barn.
"Bullshit and Brilliance Comes with Age and Experience" "Hey Lady, ya wanna buy a Grit?" "If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers |
01-25-2015, 09:15 AM | #13 |
Re: Is my fan OK?
Removed my 4 blade last week and replaced with the new style 2 blade fan. I could see some rust streaks coming from the fan rivets,( not sure if that means anything). I was going to rebuild my pump anyway so now I have one less thing to worry about. Replace the pump studs with the new style bolts that look like studs and new belt too. They did a nice job of making that 2 bladed fan too.
01-25-2015, 09:47 AM | #14 |
Re: Is my fan OK?
Probably worth keeping as example of what didn't work.
"Those who are unaware of the past are doomed by fate to repeat their mistakes." Paraphrase George Santayana. Joe K
01-25-2015, 10:43 AM | #15 |
Re: Is my fan OK?
You can use the old fan to make a whirligig.
I sure wouldn't be driving with a known cracked fan. |
01-25-2015, 11:01 AM | #16 |
Re: Is my fan OK?
I have a 50+ mile trip to make end of March to Larry's house. It will not be a worry free trip.
01-25-2015, 11:13 AM | #17 | |
Re: Is my fan OK?
Given you have time, just go pop the money and buy a decent two or six blade fan. It's cheap insurance on both making the trip without incident - and for possible damage incurred along the way. (Could be up to a grand depending on radiator/hood damage.) Besides - we'd hate to lose an example of what doesn't work to a bigger example of why it didn't. Joe K
01-25-2015, 11:20 AM | #18 | |
Re: Is my fan OK?
01-25-2015, 11:56 AM | #19 |
Re: Is my fan OK?
Do you have a trade school nearby with young mechanics in training who would take great delight in being involved?
Or even bring the new fan and drive the car to a modern Ford garage? They might charge you $90 an hour for the work - but they might also do it for free just for the photo-op. Gosh, I would like to see/try that myself. Fred Baldelli of the Chevy garage in Westboro, MA was a mentor of sorts to me. He drove daily a 1936 Ford pickup to his work - but having started as a mechanic and worked his way up to shop manager everyone knew WHY Fred insisted on driving that old Ford. And not one of them was without envy of Fred, both for his talent with tools AND for his antique truck. And surprisingly, people like Fred are still around - still in the auto trades - and are worth knowing when and where you can find them. I wish I was closer - I would fix you up in about 30 minutes. Good luck. Don't drive a broken fan. Joe K
01-25-2015, 11:59 AM | #20 |
Re: Is my fan OK?
Thanks....wish you were closer too. No trade school around here, just a lot of moonshine stills.
