11-19-2014, 08:38 PM | #1 |
engine oil pump
The oil pump drawing seen in vendor catalogs dawn by the late Howard Barnes show a single hex bolt retaining the oil pump screen cover. I have one that I recently removed from an engine that has two straight slot screwdriver bolts holding the cover in place. I also came across one that does not have any bolts holding it. The method of attachment is the peening over of the metal on the collar it fits down over. I suspect this is an early version and was discontinued because they came loose. I would think it would create strange noises coming from the engine.
Can anyone provide information about the evolution of the Model A oil pump. Tom Endy |
11-19-2014, 09:46 PM | #2 |
Re: engine oil pump
The early pumps that I have has the screen cover soldered in place. These pumps mostly have a forged housing rather than cast like the later oil pumps. The early pumps usually have an under cut shaft like the B pump but use different thickness bushings. I always avoid using this type oil pump but many were used well into 1929 .
11-19-2014, 09:53 PM | #3 |
Re: engine oil pump
Hi Tom,
You can find lots of info about the oil pump on Pluck's website under "Additional Studies" - http://www.plucks329s.org/studies/studies.htm -DAN |
11-19-2014, 10:08 PM | #4 |
Re: engine oil pump
I just tried it . A popup jumped up with an allow or don't allow choice. I made the mistake of clicking on the allow choice. No info about oil pumps showed up. I had to shut down my computor to get off of it. I don't recommend going there.
11-19-2014, 10:14 PM | #5 | |
Re: engine oil pump
Here is a direct link; http://www.plucks329s.org/pdf/studie...P_ASSEMBLY.pdf
11-19-2014, 10:23 PM | #6 |
Re: engine oil pump
11-19-2014, 10:27 PM | #7 |
Re: engine oil pump
Purdy, Pluck's file is in the widely used Adobe .pdf format - (portable document format) for sharing files across all computer operating systems. You need a free Adobe PDF Reader file to access these files; it appears that your browser may be trying to install a PDF reader to allow you to read the file.
11-19-2014, 10:54 PM | #8 | |
Re: engine oil pump
11-20-2014, 12:10 AM | #9 |
Re: engine oil pump
Purdy,
What is your email address and I will send you the document by email. OR you can view it in a 2014 issue of Model A News. Pluck Last edited by Steve Plucker; 11-20-2014 at 12:17 AM. |
11-20-2014, 06:34 AM | #10 |
Re: engine oil pump
thanks pluck for your time and effort on all the research and documentation that you do. the majority here really appreciates it and references it often
11-20-2014, 09:15 AM | #11 |
Re: engine oil pump
Great information on oil pumps thanks for sharing.
11-20-2014, 01:16 PM | #12 |
Re: engine oil pump
I guess Purdy isn't interested.
Pluck |
11-20-2014, 01:27 PM | #13 |
Re: engine oil pump
Thanks Pluck, I am interested an will send you a pm later today.
11-20-2014, 02:42 PM | #14 |
Re: engine oil pump
Purdy is VERY interesting (in my book anyway!)
11-20-2014, 02:45 PM | #15 |
Re: engine oil pump
Hey Steve,
THANKS, for all the work that you have done to help keep us informed ! |
11-20-2014, 03:55 PM | #16 |
Re: engine oil pump
11-20-2014, 04:00 PM | #17 |
Re: engine oil pump
My thanks to Steve Plucker. He sent me his dissertation on Model A oil pumps.
Tom Endy |
11-20-2014, 10:15 PM | #18 |
Re: engine oil pump
My thanks to Steve also . I received his dissertation on the many model A oil pumps and changes, some older than the soldered cover pumps that I have in my collection. My thought is that the later pumps with the bolted on cover is the better way to go in any case .
01-03-2015, 12:43 PM | #19 |
Re: engine oil pump
My engine number in my 1929 Model A is A2027757 so the engine is July 1929. I wanted to change the oil pump screen so I removed it. My screen cover is peened on as stated earlier but I could still remove the screen. When I look at the parts catalog I see a lower plate gasket which my pump doesn't have, should it have one? When I scrapped the pump housing surface it appears that it had maybe a liquid type sealer and certainly not a Form A Gasket type material between the pump housing and the lower cover plate. I hope the screen can be easily push on once I resolve the gasket question?
Thanks for any reply! |
01-03-2015, 01:30 PM | #20 |
Re: engine oil pump
I don't use the lower gasket. The lower gasket is only sometimes needed as a shim if repro pump gears rub the lower plate. a lower gasket increases the area inside the pump and decreases oil pressure.
