09-18-2014, 12:22 AM | #1 |
Early Ford V-8 Parts 4 Sale
City:
Rising Sun
State:
Maryland
Price:
In Ad
Prices DO NOT include shipping costs. Page down to see complete listing of parts and all pictures. PM/email me if you have any interest. This listing is continually being updated to remove sold items and/or add new items. If you have '35 parts you might like to trade for any of these parts, please let me know by sending a PM or an email.
● Ford script 2LF battery. Case could be gutted and used to conceal a no mantainence gel cell type battery. $75.00 ● '37 column drop. Nice, complete and original drop removed from a restored coupe that was being street rodded. Smooth working mechanism and ignition lock cylinder with key. Use as is in a driver, or repaint the housing and use in a restored show car. $250.00 ● '36 column drop. Nice, complete and original drop that's on a '36 steering column being parted out. This drop has a one year only ignition lock cylinder with keys. Use as is in a driver, or repaint the housing and use in a restored show car. $250.00 ● '36 under radiator splash pan for passenger car or light commercial vehicle $100.00 ● '33-'41, 3 bolt timing gear cover/front distributor mount in good condition... $25.00 ● '37-'41 front wishbone to axle perch pins.... $75.00/pr. SALE PENDING PAYMENT ● '35 -'36 tudor sedan left and right side doors. These doors were stored leaning against the side of a shed/barn, and were protected by the roof overhang. However, the bottoms did not fair as well due to ground moisture. Someone with sheet metal skills can repair these, or salvage the side panel skins, and other parts, to repair other doors. $75.00 each. l do not care to ship these, buyer must pick up, or arrange shipping, or II could possibly deliver these to a prearranged East Coast car show or swap meet. ● '35 - '36 right and left rear doors for fordor sedan. A nice pair of doors requiring little or no repairs before installing. Original paint and some original pin striping still exists.... $550.00 for the pair. l do not want to ship these, so buyer must pick up or arrange shipping. ● '37 Ford original used gas tank. No need to put in a repro tank, that usually doesn't fit well, when an original is available. This tank could be used on a show car, or on a nice original driver. There is a dent on the lower front area, but this can be straightened. See attached pictures. $165.00 ● '40 - '48 side load transmission case, and shifter side cover with shift levers, in good condition. Gears were removed from this case and used to upgrade an earlier top load transmissions. If you have a dameged case, with good gears, you could drop your gears right into this case and be back in business. $35.00. Note: rear transmission mount is not included with case. ● '32 to early '35, 56 tooth, aluminum press-on type timing gear. These gears are difficult to find when you really need one, especially in aluminum.....It is in either NOS/NORS condition....$45.00. ● '34 to '41 good used camshafts for 60 & 85 hp engines. Some of these are considered to be the early "long" cams, with front hub for a press-on timing gear, and others are later for bolt on timing gears. These cams can be used as is for a stock engine rebuild, or as a core to have reground into a preferred lift cam, such as a KIWI L100, reground by fellow Fordbarn member, "KiwinUS" Tony...$60.00 ea./(2) for $110.00 ● '35 - '38 brake & clutch pedal assembly. Would need new bushings, but otherwise in nice original condition. $75.00 ● '33 - '36, '37 - '48, or '49 - '53 Ford water pump cores for rebuild. You would get a good housing, and in most cases with an original Ford part number, and a good pulley. All other components will be removed. I can either ship these cores directly to Skip Haney for rebuild, or to your location, whichever you would prefer. $25.00 ea. ● '37 85hp passenger car radiators in nice condition. One is a used original and another one has been recored. $200.00 for either radiator. ● '36 original part numbered passenger car hood ornament in useable condition. It looks like the very tips of the "V" are missing, but have been smoothed down and rechromed or polished in that area or maybe it was made this way originally, I am not sure. Look at the attached picture and decide for yourself. A great piece for a driver vehicle @ only $30.00 ● '36 passenger car rear spare tire mounting bracket $35.00 ● '35 passenger car rear spare tire mounting bracket $35.00 ● Pair of '49 - '53 Mercury cast iron 8CM heads in good condition. Most of the original paint is beneath the oil/dirt coating. $30.00ea./$55.00/pr. ● '49 - '53 Mercury cast iron intake manifold with 4 stud carburator mounting $45.00 ● '48 Flathead 8rt engine block & crankshaft removed from a '48 1/2 T pu truck in the 70's..$325.00 ● '46 - '48 Ford 59ab cast iron heads....$35.00 ea./$65.00 for the pair. ● '46 - '48, good used 59 crankshafts. Mains measure from 2.4880" to 2.4965" and rods measure from 2.1280" to 2'.1370". $85.00 each ● '35 original aluminum intake manifold.....$65.00 ● '36 original aluminum intake manifold....$65.00 ● '37 - '39 original aluminum intake manifold... $65.00 ● '34 original aluminum intake manifold. Has been bead blasted. ..$80.00 ● '35 front engine mounts/water inlets for lower radiator hose connections. $60.00/pr. ● '35 - '36 center of X member. This is not the complete X member, just the very center piece that is riveted in place. $50.00 ● set of water pump block off plates for use on '37 to early '38 21 stud engines when used in '33 to '36 Fords with 21 stud heads and water pumps mounted on front of heads... $45.00/set ● '35 - '48 flathead engine oil pans.... $70.00/ea. ● '35-'36 emergency brake hand lever $50.00/ea. ● '35-'36 cowl vent door $35.00 ● '35 - '48, 4.11:1 ratio ring and pinion gear set with 10 spline pinion w/matching numbers, in excellent used condition. Some folks prefer this ratio gear set to use in their 2 speed Columbia rears.... $120.00/set ● '35-'36 front wish bones in nice original condition... $150.00 ● '35-'36 rear axle housings with nice wheel bearing journals... $70.00/ea. ● '35 3 speed transmission. Complete, low mileage item with nice gears. Includes top shifter mechanism with original shift levers, and all internals. Transmission is in excellent condition... $300.00 ● '36 steering column complete with steering wheel, light switch rod & horn button, column drop w/working lock cylinder & key, nice column tube, and steering gear box with no play...all in good working condition for $450.00 ● '35-'36 touring sedan trunk lid. Has original black paint, and in very nice original condition, with no rust ever... $65.00 ● '35 to '37 pickup truck left, drivers side door. This door will also fit the larger trucks that use the same size cab. In good condition..$275.00 ● Kari-Keen Accessary Car Trunk assembly that will fit '33 to '36 slant back tudor/fordor sedans, convertable sedans, and phaetons. This is the complete accessary attachment trunk with all necessary pieces and hardware to attach to your vehicle. I paid a lot of $'s for this trunk to use on my car during tours, but have since found a trunk that will sit on and attach to my luggage rack and have now decided to sell this Kari-Keen Trunk....$1800.00 obo PM or email me if interested in any of these parts or if you have any '35 parts you might want to trade for any of these parts. Prices shown do not include cost of shipping Offering free delivery for any of these parts to the Fall Hershey swap meet/car show, or other swap meets/car shows on the East Coast/Mid Atlantic area
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 02-03-2017 at 11:12 AM. |
09-21-2014, 03:30 PM | #2 |
Re: Early Ford V-8 Parts 4 Sale
More pictures for ad....
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 11-22-2016 at 11:33 PM. |
09-21-2014, 04:38 PM | #3 |
More pictures of parts in ad.....
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 02-01-2017 at 12:34 PM. |
01-06-2016, 09:01 PM | #4 |
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 02-01-2017 at 12:17 PM. |
01-17-2017, 02:16 PM | #5 |
Bttt
01-20-2017, 11:56 AM | #6 |
01-23-2017, 05:06 PM | #7 |
Bttt
01-26-2017, 11:26 PM | #8 |
Bttt
01-30-2017, 08:54 AM | #9 |
Bump
02-03-2017, 12:36 AM | #10 |
Bttt
02-07-2017, 09:30 AM | #11 |
Bttt
02-12-2017, 11:38 PM | #12 |
Bttt
07-08-2017, 07:42 AM | #13 |
Bump
07-12-2017, 07:23 AM | #14 |
Bttt
07-15-2017, 10:27 AM | #15 |
BTTT...
due to Ryans changes for editing old posts and ads, I can no longer make changes to the original ad. Some of these items have been sold or prices may have changed, so if you are interested in anything on this list, please send me a pm.
07-22-2017, 08:55 PM | #16 |
Bttt....see post #15 above for details
07-26-2017, 02:48 PM | #17 |
Bttt
08-03-2017, 01:12 PM | #18 |
Bttt
08-07-2017, 10:49 AM | #19 |
Bump
08-11-2017, 02:14 PM | #20 |
Bttt
Note: Some items on original list have been sold, but due to changes made to this website, the original listing can not be edited to reflect this. ● 36 column drop.....SOLD ● 37 column drop.....SOLD ● 35-36 front wish bones....SOLD ● 32-early 35, 56 tooth aluminum timing gear....SOLD ● 37-41 perch pins....SOLD
