Old 09-05-2014, 12:24 PM   #1
Terry,NJ
Terry,NJ's Avatar
Default Real old time valve seat cutter
I bought one today! It was in a rickety wooden box, several anghle cutters, a support arbor, couple of crank handles. 3 flat cutters for new seat inserts. etc. But only one pilot, if you can call it that. But not a clue how the dam thing works. The name "Rigid" is stamped into the back of some of the cutters. There are 5 deg, 15 deg, 45 deg. and 60 (?) deg.
1) Any one know if this is complete?
2) what these things are going for?
3) I tried researching it on line but not much luck. Any info would be appreciated.
I date it about 1910 - 1920, maybe older.
Thanks, Terry
Terry,NJ is offline   Reply With Quote
Old 09-05-2014, 12:43 PM   #2
bart78
bart78's Avatar
Default Re: Real old time valve seat cutter
I have a old rigid valve seat cutter. But it's for plumbing. I did not know they made any for cars. I guess when we were manufacturers and not importers. Company's made all kinds of stuff.
bart78 is offline   Reply With Quote
Old 09-05-2014, 03:59 PM   #3
pooch
pooch's Avatar
The ' rigid' name in plumbing tools is ridgid.
pooch is offline   Reply With Quote
Old 09-05-2014, 04:22 PM   #4
Terry,NJ
Terry,NJ's Avatar
The name is written in script form and appears to be, The Rigi t or Rigi d or Rigid master. It's kinda hard to say just which, Down below, It says Mowser, Indianapolis , in a smaller, but a sort of printed Font (New times roman?) The cutters all have a bronze bushing that spins on a pilot (Which I don't think I have) They are marked with the dia. ( 2" ) and the angles. Thanks, Terry
Old 09-05-2014, 07:51 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
Some Chevy valves were 30*, so your set is probably missing that cutter. I bought a couple partail sets at farm auctions years ago or at swap meets if they are cheap. For grinding valves and seats I use my electric grinder with stones.
