Go Back   The Ford Barn > The Archives > Model-T
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default '27-'27 roadster windshield
I'm trying to restore an old rodded roadster to original, and want to know what type windshield was original. I've seen some with a two piece split and some one piece that were a little shorter that the two piece. Any info is appreciated.
<table><tr><td><font face="arial">
Old 01-01-1970, 12:00 AM   #2
Guest
Posts: n/a
Default Re: '27-'27 roadster windshield
I believe the two piece split is correct.
Old 01-01-1970, 12:00 AM   #3
Guest
Posts: n/a
Thanks for the reply. I wonder where the one piece windshields came from?
Old 01-01-1970, 12:00 AM   #4
Guest
Posts: n/a
It probably came from a hot rod shop. Wolf !!
Old 01-01-1970, 12:00 AM   #5
Guest
Posts: n/a
I bought a rusty one via ebay. It has the wiper fitting, the push/pull handle at the bottom, rubber seal grove for the cowl, and swivels match the T stanchons. It matches the curvature of the cowl. I've conviced myself it is from Ford. I'd appreciate any info or comments. I'll supply any measurements needed. We can communicate via email if desired and I'll post any results here for general information.
Old 01-01-1970, 12:00 AM   #6
Guest
Posts: n/a
The one piece is a hot rod windshield for chopped top or no tops.
Runnig with the top down and the winshield closed causes too much wind on the back of your neck. And side wind.
If you block the top half open about 1 1/2 inches it drasticly reduces wind eddies on you.
Makes much more pleasant driving at higher (35-65 mph) speeds.
Old 01-01-1970, 12:00 AM   #7
Guest
Posts: n/a
Old 01-01-1970, 12:00 AM   #8
Guest
Posts: n/a
I am in need of the bottom most pasenger side clamp to hold the top 1/2 of the split windshield on my 27. Any one have one the would like to sell to me? Mick
