Old 06-24-2014, 06:24 PM   #1
DougVieyra
DougVieyra's Avatar
Default Are the current manufactured inner-tubes still bad ?
I am getting ready to mount tires on two sets of rims, and need to buy 12 new inner-tubes (six @ 19" & 6 @ 18"). In the past few years I have heard a great many stories about failed tubes from all the manufactures.
Does anyone know what the 'latest' information is on the recent batches of inner-tubes now coming to the market place ? Are there still some 'bad' ones out there, or are are they ALL GOOD now ?
DougVieyra is offline   Reply With Quote
Old 06-24-2014, 06:30 PM   #2
machine girl
Default Re: Are the current manufactured inner-tubes still bad ?
If your not into show motorcycle tubes (dirt bikes) are super thick . and have metal stems , we use 400-425 x 19 inch never had to call AAA.
machine girl is offline   Reply With Quote
Old 06-24-2014, 06:31 PM   #3
Growley bear
I purchased new tires and tubes from Snyder's in December 2013 and they now have 600 trouble free miles. I check the pressure once a month and in that time I believe that I only had to add a minute amount of air once. The Snyder tubes are made of all new rubber, not a mix of recycled stuff.
Chet
Growley bear is offline   Reply With Quote
Old 06-24-2014, 06:51 PM   #4
Herb Concord Ca
Try Bert's in Denver CO.
I bought 4 this spring based on comments on this site.
They saw Radial on the stem and the bag says 100% butyl rubber.
I've put about 1000 miles since they were installed and no trouble so far.
Herb Concord Ca is offline   Reply With Quote
Old 06-24-2014, 07:15 PM   #5
C26Pinelake
If Walt Bratton says it, you can take it to the bank ! He is indeed a gentleman.
Wayne
C26Pinelake is offline   Reply With Quote
Old 06-24-2014, 07:45 PM   #6
glenn in camino
glenn in camino's Avatar
Originally Posted by 1930 coupe View Post
This is a post from Walt Bratton from a year ago.
About 10 years ago we at Brattons started making our own inner tubes because we had issues with the tubes that were currently on the market. When we had one of the tubes analyzed we found out that those tubes were being made with a high percentage of recycled rubber, and the thickness was severely lacking. So when we had ours made we had these tubes made with 100% new rubber and much thicker for longer life. Since we have started making and selling our own tubes the failure rate has decreased. I know the tubes are a bit more expensive than the others on the market, but we have had much better success with them.
I bought tubes from Brattons about 6 months ago and haven't used them yet. They say made in China on them.
glenn in camino is offline   Reply With Quote
Old 06-24-2014, 08:30 PM   #7
Mitch//pa
brattons are made off shore but to his specs excellent quality
if your buying tubes it would be a wise choice to go with his
Old 06-24-2014, 08:36 PM   #8
29 Tudor
29 Tudor's Avatar
I had two tubes from "another" supplier and they both had slow leaks (in the same tire). I bought a new one from Brattons and haven't added any air since. It's been about three months. I LIKE their tubes!
Steve
29 Tudor is offline   Reply With Quote
Old 06-24-2014, 11:02 PM   #9
Arlyn Bieber
Try Kelsey Tire in MO. They make the Goodyear tires. Their tubes are thick rubber and excellent quality. Sometimes you get what you pay for, try Kelsey Tire.
Arlyn Bieber is offline   Reply With Quote
Old 06-24-2014, 11:17 PM   #10
Pete
I have used them also. Several choices on stem style.
Choice of natural or butyl rubber.
Good stuff.
Old 06-24-2014, 11:50 PM   #11
Barber31
Barber31's Avatar
So which is recommended, natural or butyl? And the difference?
Barber31 is offline   Reply With Quote
Old 06-25-2014, 01:06 AM   #12
P.S.
I just recently bought a set of tires and tubes from Las Schwab. The tires obviously came from Coker (Firestone's) and the tubes are made in USA. The tubes are excellent! Very thick and in over 1000 miles, have not had to add air to any of them. They are all still at exactly 35 PSI whenere they were when I drove the Model A out of the tire shop.
P.S. is offline   Reply With Quote
