Old 06-19-2014, 06:20 PM   #1
A-Man
Default U-Joint Gaskets
When installing the inner cover and outer cover halves over the universal joint, should any type of material be placed on the gaskets and the outer cover ends to help reduce leakage? Would PERMATEX Copper Spray-A-Gasket hi-temp adhesive sealant be a good choice?
Thanks.
A-Man is offline   Reply With Quote
Old 06-19-2014, 06:49 PM   #2
tbirdtbird
Default Re: U-Joint Gaskets
permatex ultra black
'31 180A
tbirdtbird is offline   Reply With Quote
Old 06-19-2014, 07:33 PM   #3
glenn in camino
glenn in camino's Avatar
I use clear silicone and wipe off any excess that squeezes out.
glenn in camino is offline   Reply With Quote
Old 06-19-2014, 08:20 PM   #4
darrylkmc
darrylkmc's Avatar
A-Man,
I would use Indian Head Gasket Shellac on one side of each gasket and Grease on the other side of the gasket. This way you can disassemble it if you want to take a look at it later and not waste the gaskets.
Darryl in Fairbanks
darrylkmc is offline   Reply With Quote
Old 06-20-2014, 03:41 PM   #5
hardtimes
hardtimes's Avatar
Thanks.
Yup, use either, but use one.
hardtimes is offline   Reply With Quote
Old 06-20-2014, 10:17 PM   #6
ctlikon0712
ctlikon0712's Avatar
I second what darrylkmc in Alaska suggested. That has worked well for me in Florida too.
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
