06-18-2014, 08:38 PM | #1 |
T5 Speedometer cable
Well, it was just discovered that during a "clean-up" session last fall during the restore, the original speedometer cable was apparently tossed out.
The cable I will now need anyway must go from the "new" BW T-5 transmission, up to the back of the stock 1934 Ford speedometer. Where would I get such a speedometer with the correct connections? This is not the electronic transmission. (Henry did not have "electronics" in his cars as I recall.) Thank you. |
06-18-2014, 08:57 PM | #2 |
Re: T5 Speedometer cable
Any speedometer shop.
06-18-2014, 09:33 PM | #3 |
My local NAPA store can make speedo cables, you might ask there....if you have one nearby.
06-18-2014, 10:53 PM | #4 |
I think a stock 34 cable will work on the t5. I know the stock 1950 f1 cable cable worked on my truck
06-18-2014, 11:13 PM | #5 |
Stock cable hooked right up on my '48 F1.
06-19-2014, 12:15 AM | #6 |
06-19-2014, 09:18 AM | #7 |
Yep - stock speedo cable works ....
