04-24-2014, 11:05 PM | #1 |
changing clutch in a 36 1 ton
I have a 36 1 ton with v8 and 4 speed. is it faster to pull the motor or move the rear-end and cross member to change the clutch?
Live your dreams |
04-24-2014, 11:16 PM | #2 |
Re: changing clutch in a 36 1 ton
Does it have a coupling in the middle of the driveshaft tube ---if so this can be dissconnected without removing the rear allowing trans removal
04-25-2014, 06:40 AM | #3 |
No it just has the rear end tube than a cross member than another tube and the cross member that bolts to the back of the trans.
Live your dreams |
04-25-2014, 06:51 AM | #4 |
It's a lot easier for me to pull the engine? Walt
04-25-2014, 07:53 AM | #5 | |
To remove the flywheel the pan has to be dropped unless a later 2 piece pan has been installed Which way is easiest probably depends on what tools you have --and what you are comfortable doing. |
04-25-2014, 12:52 PM | #6 |
Live your dreams |
