04-23-2014, 01:00 PM | #1 |
Wico JEM Magneto questions
Does anybody know what the amount of auto advance is in a Wico JEM magneto?
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
04-23-2014, 02:09 PM | #2 |
Re: Wico JEM Magneto questions
There is no auto advance in the Wico Magnetos.
04-23-2014, 03:14 PM | #3 |
There is in the JEM models. I just don't know how much.The Wico JEM 1509 models were made specifically for Fords.
04-23-2014, 09:45 PM | #4 |
No advance. There is a retard feature called an impulse drive. It retards the timming for starting. Once the engine reaches idle speed,the timming is fixed.
04-23-2014, 11:33 PM | #5 |
If it retards to start then advances that is what I mean. I am just trying to find out how much the retard/advance is?
04-24-2014, 08:44 AM | #6 |
04-24-2014, 11:55 AM | #7 |
Specific for Ford industrial engines usually farm equipment.
If the mag has the impulse it will have what is called a lag angle instead of calling it an advance. usually 9 to 12 degrees. the impulse mechanism should kick out at from 150 rpm's to plus 200 rpm's. Initial timing is set at TDC turn mag shaft until impulse snaps at number 1 post on mag cap then install and align number 1 wire to number 1 cylinder. Then adjust as CDO said usually just so it doesn't kick back at cranking speed. The magneto runs at what ever you set it at but the rotor lags behind at cranking speeds at what ever the lag angle built into the magneto so you could say it retards the spark that amount but again , it is called the "lag angle". I remember when some engines had a manual impulse that was a small lever on the magneto that you set before cranking because they had no starter and had to be hand cranked. Been there, done that, but didn't get a T shirt Last edited by just plain bill; 04-24-2014 at 12:13 PM. |
04-24-2014, 12:40 PM | #8 |
Thanks to you all for sharing.
04-24-2014, 02:45 PM | #9 |
Not hijack the thread, I have been told that Porsche distributors or mags can be adapted to Model A/B motors.
Has anyone here done this? I have an old one, it indicates 0° 1750 - 12 1/2° 1900 This would be nice as long as the 1700-1900 is crank speed and not mag speed. My side drive Bendix has lag, I can just imagine trying to hand prop an old airplane without it. John |
04-24-2014, 03:06 PM | #10 |
John,
I have seen those Mags too. The ones I've seen are Vertex mags. I have talked to some one at Don Ziggs about centrifugal advance on vertex mags and they say yes, it is possible. I haven't done it yet, but I do have a 4 cyl. Vertex mag that I would like to send to them and have it set up for the street. If I recall correctly, the VW / Porsche mag run the opposite way then a Model A / B.. Last edited by Crazydaddyo; 04-24-2014 at 03:29 PM. |
