04-19-2014, 09:00 PM | #1 |
9" No Spring Clutch
I'm Looking for a clutch disc 9" or 9.5" with no dampening springs. I'm told the early model-A's had these?
Is there a supplier for new ones? Or if anyone has any usable ones to sell? I have a V8 flywheel to go on my model-A and I cut it down a little too far removing weight, now the springs on my clutch disc are VERY close to the crank bolts. Thanks for any help Zach
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads |
04-19-2014, 09:35 PM | #2 |
Re: 9" No Spring Clutch
I'd give Bert's a call. 800-321-1931
They are closed Sundays and Mondays. |
04-19-2014, 09:47 PM | #3 |
you won't like it....
'31 180A |
04-20-2014, 08:54 AM | #4 |
Thanks guys
this is for a model-A roadster dirt track racecar. so it will be in one gear almost all of the time. thanks Zach
-WANTED-
04-20-2014, 11:29 AM | #5 |
Try some Chev flywheel bolts, they have thinner heads.
Lock them down with sleeve thread locker, (also keeps the Ford from rejecting the Chev parts). JB |
04-21-2014, 10:17 AM | #6 |
04-21-2014, 01:30 PM | #7 |
Hey Zach,
Jerry has good advice about the chev 'thinner' head bolts. Let's see you car,eh ! |
04-21-2014, 07:41 PM | #8 |
-WANTED-
04-29-2014, 09:21 PM | #9 |
Very cool! I have a AA clutch disc that's in good shape. Pay the shipping and it's yours.
04-30-2014, 05:29 AM | #10 |
04-30-2014, 08:52 AM | #11 |
cool car zach . hope you have found one by now ! ........... steve
V4f |
04-30-2014, 09:07 AM | #12 |
I had 2 of these religned 25 years ago. I have not used them, so they are still on the shelf. Will take $20 each for them. PM me if interested. Rod
04-30-2014, 09:33 PM | #13 |
Thanks everyone. I have now received a few. Seems the hub sticks out the back a little farther then the spring type. It was hitting the flywheel bushing before the disc was touching the flywheel. I just put it in the lathe and took a bit off the backside.
Now keep in mind, I took 1/4" off the face of the flywheel... so this may not be an issue with a stock V8 flywheel. But anyways, the good news is.... it works! Sitting in the garage, I got the whole set-up to work tonight! Model-B starter with a reversed bendix , cut down V8 flywheel and a 9" no spring clutch. Hopefully in a few days I can test drive the chassis around the yard! thanks everyone for all of the help and to those of you who supplied parts!! Zach
-WANTED-
04-30-2014, 09:58 PM | #14 |
Don't believe all you hear from some others. I run one like this in my cabbie and have never had a minutes problem. No chatter or slipping at all. I would run one like this the same as one with springs.
05-01-2014, 07:22 PM | #15 |
Well, that didn't go to well!!
I'm thinking I have too many variables in place here... I had the engine running fairly well with a stock flywheel and starter. Then put on the new cut down V8 flywheel and a starter with a reversed bendix... Somehow in the course of a few days something seems to have gotten weird, I think with my timing. We got it running, but it was firing out the exhaust pretty bad (big flames) and the exhaust manifold got REALLLLLYYYYY HOT!!!! So I tried to get back to square one with the timing of the WICO magneto. In the effort of cranking it so much... eventually... SNAP! Everything jammed! Here is the result.... offerings to the gods of speed? I'm going to put up a new post about the WICO.. hopefully its not too far off path with the restoration nature of this site. Zach
-WANTED-
05-01-2014, 09:31 PM | #16 |
I saw a NOS one on ebay today
