03-21-2014, 11:01 AM | #1 |
Heavy drag on rear drums II
Not wanting to hijack the O.P. but sense we are talking about brakes I also have a problem with the rears. After relining the shoes for both drums they fit tight but the right side was real tight. I could move it by hand but it was hard, the left side I felt was OK but it was snug. (Adjuster back all they way out)
I have Mr. Gross's drums and brakes on the front, everything was done by him and they would drag a little but this seems normal. I now have braking power that seemed impossible with mechanical brakes, as far stopping goes I could not be more pleased. One of the rears will squall not squeal but out right squall when braking hard, sounds like a big bus or truck stopping. The rears are woven lining and steel drums. The fronts after some spirited braking will run from 170 to 200 degrees. The rears will run about 115 to 125. I have the rears adjust one click back from almost locking up trying to turn it by hand with the wheel one, same with the fronts. Does this seem right? also what is up with the loud squall. thanks! dusty |
03-21-2014, 11:05 AM | #2 |
Re: Heavy drag on rear drums II
Not using original style brakes?
1928 Model A Business Coupe Rebuild picture gallery here The light at the end of the tunnel has been turned off due to budget cuts. |
03-21-2014, 11:15 AM | #3 |
I'm thinking the squall is you haven't "tapered" your linings between center and leading and trailing edges.
The optimal condition is to have the greatest PSI right at the centerline of the shoe, with decreasing psi as the measure is taken to the leading and trailing edges. I think what you have is either equal pressure, or possibly the shoe is contacting the leading and trailing edges, which set up the center of the shoe like a guitar string. I'm surprised you are going with cast iron fronts and steel rears. The fading action (think expansion by heat of the drum) of the steel rear compared to the front may be adding your tendency to squeal. And the relatively rigid front is letting the rear get the squeal on. Certainly taper your shoes in the rear. Better would be to put cast iron all the way around. More for "consistancy sake" in braking - and to prevent any interplay between the cast iron and steel drums being reflected through the linkages. Ford in the day advocated that 2/3rds of the braking action should occur on the rear shoes. This to prevent the rear from "swinging around" on application of brakes. I agree with your setup generally though. My experience has been that 2/3rds of your brake action should be on the front thus taking advantage of the natural tendency of the contact pressure of the front wheels to increase on stopping. Modern drivers have learned to compensate for swinging of the rear of the car during braking by "steering the skid." Maybe in 1930 this ability wasn't as much required? Traffic may not have been as tight for drivers in 1930 either? Joe K
Shudda kept the horse. |
03-21-2014, 11:43 AM | #4 | |
your overheating them also the car needs to be jacked up under the axles or the brake rods will pull if supported by the frame. on a lift i usually disconnect the brake rods so i can work on them Last edited by Mitch//pa; 03-21-2014 at 11:48 AM. |
03-21-2014, 01:01 PM | #5 | |
thanks all dusty |
03-21-2014, 01:03 PM | #6 |
03-21-2014, 01:06 PM | #7 | |
03-21-2014, 01:08 PM | #8 | |
The linings I got from Snyder's were tapered at the ends, should I have done more than that ? thanks dusty |
03-21-2014, 01:47 PM | #9 |
I am wondering if you are running original style brakes or if you have changed them to hydraulics.
03-21-2014, 02:01 PM | #10 |
03-21-2014, 02:03 PM | #11 |
I also run cast iron on front and steel on the back. I have no problem with the set up. If I remember right you told me that you pressed the steel support ring on the steel drums. If so they may be out of round ,Maybe that's why they are tight. maybe they did to be bored to true them up.
03-21-2014, 02:03 PM | #12 |
03-21-2014, 02:06 PM | #13 |
If the adjustment is backed all the way out, the controls are well lubricated, and you are still dragging, I would say to take the drums to a shop and have them turn them down a few thousands of an inch. Not much. Maybe .005".
Alternately, you can have the shoes re-arched and remove a little material off the pads to get the clearance you need.
03-21-2014, 02:07 PM | #14 | |
dusty |
03-21-2014, 02:22 PM | #15 | |
I have no clue as to how to arc them and I have read everything here that I could find but it still escapes me but then again most things do I could take them apart again and take the ends down some more and maybe the high spots will revel them self's now and sand them down. Now as far as turning the drums?? I only have one place here that can do them and I'm not sure they completely understand what they are doing. I took the front drums to them to be turned and they looked fine but after 2000 miles the linings had started to strip pieces of the drum away. That material became in bedded in the linings and that metal cut deep rows in the drums. Did they take to much of the drum away?? maybe someone can explain why that happened. thanks dusty |
03-21-2014, 02:24 PM | #16 | |
03-21-2014, 02:33 PM | #17 | |
I tapered about 1 to 1-1/2 inch on mine. But a "long" taper. Somewhere on another thread I described a DIY version I used in the 1980s to 'arch' my shoes. This using an artists spray adhesive and 100 grit paper applied to the inside of the drums. And then carefully working the shoes out and using the paper to "mate" the shoes to the drum. With the paper removed, the contact of the shoes to the drum interior is "hardest" in the center and less so at the leading and trailing edge. I suppose when done in this manner it removes the necessity to taper - although I did that too as above - a couple of swipes of the mill file. Well, everyone I talked to said to do that. Today I would search out the pressure sensitive adhesive backed grit papers that are frequently available in half sheets for use with electric sanders. It really takes doing all four wheels at once. And each done the same. You then tie it all together using the linkages and then one by one "equalize" (match) the pressure of the shoes on the drums. Once this done then give the fronts a bit "more." I could see cast iron drums would naturally give the front "more." Cast iron is much more "consistent" than pressed steel drums. I used a sand covered road to see which wheel "caught first" on gentle application of the brakes. When all were pretty much adjusted the same (and skid together) then I "goosed" the front somewhat so that each side skidded before the rears and equally. Then I did much the same on a macadam road (tar) at increasing brake pressure and to the point where the front skidded first. This about the optimal braking limit of narrow tires. It's a little bit of an art - and persistance to get it right. Joe K
03-21-2014, 02:34 PM | #18 | |
Also to be honest with all the hills around here I'm not sure if there is a gentle brake in procedure that you can follow I will put on some more miles to see what happens. I was most concerned about the temperatures but just based on what I found with the temps maybe the dragging is not a big concern.....but that is why I asked here. thanks dusty |
03-21-2014, 02:41 PM | #19 | |
Thanks all for your time dusty |
03-21-2014, 04:54 PM | #20 |
Some say the rear e/brake linings are oversized, may be why yours are "tight". Not sure if you put "bands" on Mel's new drums or the old ones. If either on the old or new, the drums should be turned. Did you center the shoes after installing? Any other mods to the braking system (Floaters, Flathead Ted's?).
Paul in CT |
