Old 02-14-2014, 12:50 PM   #1
Ron Lowe
Default Cut-out follow up
I noticed my amp gauge was not showing a charge. I thought my problem was the cut-out so I used a jumper cable to bypass the cut-out and it did show a normal charge. With nothing to loose I took the cut-out apart and found the diode to be good but the solder had broken. After re-soldering all is working well. Hope this helps someone
Ron Lowe is offline   Reply With Quote
Old 02-14-2014, 01:06 PM   #2
jm29henry
jm29henry's Avatar
Default Re: Cut-out follow up
that great for once a easy fix!!
jm29henry is offline   Reply With Quote
Old 04-23-2014, 08:31 AM   #3
fordUSA
Would you happen to have the spec on the diode? Any number on the side of it would be a big help. Thanks.
fordUSA is offline   Reply With Quote
