02-11-2014, 11:07 AM | #1 |
Seeking Good Used Magnaflux
I am seeking to buy a good, used, working magnaflux.
Please contact Chris at: 903-819-1452 or at [email protected] |
02-14-2014, 03:57 PM | #2 |
Re: Seeking Good Used Magnaflux
I made my own using a GM solenoid, a trickle charger and some iron bar. Magnetic powder and a "puffer" from Goodson's in Winona, MN.
03-05-2014, 02:52 PM | #3 |
van dyck,
Please tell us how to build it. Fourdy |
03-07-2014, 03:39 PM | #4 |
The round bar is 4.5" long by 1.25" turned down to just fit into the solenoid (car guys do have friends who have lathes, don't they?) with a 3/8 NF drilled and tapped hole on one end. The down legs are 1" square stock, 4" long with one leg welded to the non-threaded end of the round bar (see pictures). Drill the other down leg so that it can be bolted to the threaded end of the round bar, after the solenoid is positioned on the round bar. I tack MIGed the solenoid shell to the round bar, and wrapped it with Duct Tape. I'm using a 6V battery tender (trickle charger), but a 12V will produce a stronger magnetic field. Connect one of the battery charger leads (does not matter which one) to one pair of solenoid wires and the other lead to the other pair of solenoid wires. But, you might consider installing an ON/OFF switch in this circuit, as seen in the pictures. The puffer and powder came from: Goodsons in Winona, MN www.goodson.com |
