01-22-2014, 06:37 PM | #1 |
Things Not To Do
How many of us have learned things the hard way? Kevin in NJ answering a novice question, more or less posted, he never uses taps and dies on Model A parts. I too learned this the hard way. The tolerances are different. Do you have anything you have learned not to do, to pass on to others?
Paul
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. |
01-22-2014, 06:50 PM | #2 | |
Re: Things Not To Do
01-22-2014, 06:57 PM | #3 |
Paul you are so right ...I didn't know there were thread chasers....just used taps and dies.....but I was young back then.... in my late 60's,
01-22-2014, 07:16 PM | #4 |
You can use adjustable dies! The one that have a little flex in themat wide open, they do a nice job of cleaning up the threads without removing stock. For nuts, I grind cutting edges into the front of an old ford bolt and screw the nut down on the bolt/stud. Not perfect, but better than nothing.
Terry |
01-22-2014, 07:28 PM | #5 |
I've learned to not put something back together the way it came apart. Look at a diagram, its surprising what people leave off/out. The crank flange dowel pin retainer comes to mind, as just one.
01-22-2014, 07:30 PM | #6 |
Darryl in Fairbanks |
01-22-2014, 07:49 PM | #7 | |
Agreed.
01-22-2014, 08:08 PM | #8 |
I learned not to let go of the handle of a ratchett type hoist while lowering a motor in place. Especially while standing on a ladder and having your chin in range of the ratchett handle. Not sure how many times it hit me but still have the scar the A and the memory.
01-22-2014, 08:46 PM | #9 |
Sorry, I use clear silicone on gaskets all the time. I wipe off the excess asap. It seems to work good and makes for a clean install and disassembly when necessary.
01-22-2014, 09:30 PM | #10 |
Never take it apart without taking LOTS OF PICTURES!!!
01-22-2014, 09:34 PM | #11 | |
I learned to wear leather gloves when trying to remove a tire from a rim by using a hammer and chisel. |
01-22-2014, 09:37 PM | #12 |
A short cheater bar in one hand and a hammer in the other is better than a long cheater bar in both hands.
01-22-2014, 10:03 PM | #13 |
01-22-2014, 10:15 PM | #14 |
Yes, Pete, Most everything is a "trade off" of some sort. Saving $$$$ by NOT buying FLAVORED COFFEE CREAMER= REALLY crappy tastin' coffee!
Bill W.
01-22-2014, 10:22 PM | #15 |
01-22-2014, 11:06 PM | #16 |
01-23-2014, 07:56 AM | #17 |
One of the first repairs that I did as a 16 year old newbie on the Coupe fifty years ago was to remove the instrument panel to repair a leaking gas gauge.
As I removed the panel I saw the insulation on the wires was all frayed with bare wires exposed but before I could remove the battery cable, the short and resulting fire started. My friend said that I made three trips to the tool box in panic before I found the correct sized wrench for the battery cable connector! The only reason that the car did not burn down to the ground was that I had removed the floor boards so there was plenty of room to unhook the cable and avoid the smoke at the same time. After installing a new wire harness the very next thing I installed was a fuse box from a VW bug. There were no fuse accessories for the Model A available that I knew about in 1963. Good idea to remove a battery cable when working on the dash panel or have a fuse installed on your A. |
01-23-2014, 07:59 AM | #18 |
Leave the trouble light in the engine bay.
01-23-2014, 08:52 AM | #19 |
I have a spare oil pan dipper tray that has four 3/32 holes drilled at the lowest point of each reservoir; this I don't understand.
Never just swedge the oil pan drain plug insert onto the oil pan. They will eventually slip when trying to remove the drain plug; just my experience. Chet |
01-23-2014, 09:14 AM | #20 |
I have learned to be careful about making any major component changes (perceived improvements) just before leaving on a road trip. A failure of an untested component has caught up with me a couple times while on the road. I guess the following applies: Don't fix it if it ain't broke.....
Good Day! |
