01-04-2014, 11:08 AM | #1 |
best way to check cylinder compression
What is the best way to do a compression check? After the engine has been warmed up and the plugs out or cold with the plugs out? Thanks
01-04-2014, 11:14 AM | #2 |
Re: best way to check cylinder compression
i think cold with all the plugs out. if any seem odd dump about 1/4 cup of oil down each cyl and run the tests again.
1929 Model AA - Need long splash aprons! |
01-04-2014, 11:22 AM | #3 |
I would suggest a thoroughly warm engine. Make sure the throttle is wide open during the test to insure complete cylinder filling. If you get a low cylinder you can do the oil in that cylinder as suggested by SeaSlugs. If the reading improves with the addition of oil in the cylinder it indicates the rings may be worn or not seated.
01-04-2014, 11:24 AM | #4 |
What are you trying to achieve? Is this to diagnose an ailment, or just for something to do? Most good mechanics will tell you that compression gauges today are really cheap (i.e.: inaccurate) so they really are lacking in accurate diagnosis.
01-04-2014, 12:08 PM | #5 |
sometimes i have to check compression on a car that wont start so then its cold. a leak down is a much better test on things IMO. opening the throttle never made a noticeable difference when doing a comp test even with a good gauge.
01-04-2014, 12:49 PM | #6 |
01-04-2014, 02:22 PM | #7 |
Remove all the sparklers and test cold. Its important to check the very first needle stroke and then the last. Warm it up and do it again. I don't worry about the throttle plate position on something like an 'A'. Compare readings between cylinders, should be fairly close to each other. You could then do the oil thing if needed. I don't worry much about how high the readings are as all gauges are not created equal, there will be differences between gauges.
If you have an air chuck adapter type fitting, then you could perform a leakage test also or if there is a problem. |
01-04-2014, 02:42 PM | #8 |
Exactly how do you do a leak down test on a Model A. I am thinking of a differential compression test done on an aircraft piston engine where you move the propeller back and forth during the test. How do you do this on a Model A? You can't move the crankshaft back and forth. Bill G
01-04-2014, 04:51 PM | #9 | |
01-04-2014, 07:12 PM | #10 |
Thanks I just want to see what the motor has for compression as it is tired. My compression guage is a snap on so I don't know if it is any better than any other quality wise. It definitely costs more , I hope that means it is better than a Harbor Freight or some cheap auto parts store junk.
01-04-2014, 07:19 PM | #11 | |
Mine shows a grand total compression of 45# on a 50+ year old engine rebuild. So its really getting tired, but, It doesn't leak or burn anything and still has enough power for what I do. |
01-04-2014, 07:40 PM | #12 | |
Sorry to be so dumb about this. Bill G |
01-04-2014, 08:03 PM | #13 |
Most compression gauges have the spark plug hole fitting with an air chuck adapter. But, just as long as you have something that screws in the plug hole an air line can be rigged to fit it. I never needed a stethoscope, your ear will work fine. If there is a problem you'll notice it at the oil filler, exhaust pipe, the intake or possibly the radiator.
01-04-2014, 08:58 PM | #14 |
Most modern comp gauges do not fit the Model A spark plug hole. You can buy the adapter used for installing the 14mm plugs into the A and thread your gauge into that. I do not trust the nipple ended gauges, only the thread in type.
01-04-2014, 09:44 PM | #15 |
Well, Marc, to answer your original question, here's the way I have ALWAYS done it:
1 Engine FULLY warm. 2 Throttle WIDE open. 3 Battery FULLY charged. 4 Crank it at least 10 strokes, or until guage no longer rises. 5 If one is low, retest it several times, as carbon may be stuck under a valve from taking out the plugs. I've used the same old inexpensive hand held guage for 35 years & checking it with a pressure regulator, it's STILL RIGHT ON. I've had to replace the valve core a time or two. And it's rubber dooley is BIG enough fur a Model A. You only need a leakdown tester when your basic test shows a puny cylinder, that will tell you WHERE the problem RESIDES. Keep it simple, it AIN'T ROCKET SCIENCE or MEDICAL RESEARCH or ATOM SPLITTING! Bill W.
01-05-2014, 09:38 AM | #16 | |
01-05-2014, 11:32 AM | #17 | |
