Old 05-11-2010, 03:20 PM   #1
rio2154
Default 26 / 27 Starter Question
Can anyone tell me if the Canadian cars used a different starter battery contact? My car does not have a foot start switch but has this lever actuated contact instead. I am just beggining to restore this car and have no idea what parts are missing to actuate this. This is a 1927 Canadian Roadster Pickup and the Starter is marked as Canadian inside the nose.
Thanks
rio2154 is offline   Reply With Quote
Old 05-11-2010, 07:00 PM   #2
jchochole
jchochole's Avatar
Default Re: 26 / 27 Starter Question
Hey just as a point of reference- I had a '22 Canadian Touring and it not only had the normal "heel" footstart button, but the floorpan had holes on both sides for either left or right hand drive position. So, maybe the flexibility was built into the foreign market. I did read an article years ago that Henry tried out new innovations on the Canadian market before the US market saw them. For example- I had a July 1922 Touring but it had the '23 one-man top. That feature hit Canada first for some odd reason.
Cheers,
Jim from IL
jchochole is offline   Reply With Quote
Old 05-11-2010, 07:29 PM   #3
Jack Innes
Jack Innes's Avatar
I have messed with a lot of Canadian T starters & have never seen this switch used. It would, on the other hand, fit correctly on my 27 Essex boat-tail. I think maybe someone other than Ford had a better idea (in their back yard).
Jack Innes is offline   Reply With Quote
Old 05-11-2010, 07:31 PM   #4
rio2154
Thank you for the info. Mine does not have the left and right positions but I do question whether every part is Canadian. I'm confused by this starter though.
Old 05-11-2010, 07:34 PM   #5
rio2154
Could be. Whoever did this did a nice job of mounting it onto the stater. I havent found anything thing else online like it.
Old 05-11-2010, 07:53 PM   #6
Roadster62
Roadster62's Avatar
That lever activator looks a lot like 1932 Ford Model B ( 4 cylinder) item, ask to see one on the V8 section. Bob
Roadster62 is offline   Reply With Quote
Old 05-11-2010, 09:46 PM   #7
rio2154
Your right Bob, it is similar. They call them kick starter switches. Now I wonder if I should and how I varify that this is a T Starter.
Old 05-13-2010, 06:45 PM   #8
Ron the Coilman
That is definitely a Model T starter with a 1932-1934 Ford Model B starter switch adapted.
Ron (the Coilman) Patterson
Ron the Coilman is offline   Reply With Quote
Old 05-14-2010, 01:38 PM   #9
rio2154
Thumbs up Re: 26 / 27 Starter Question
Thanks Ron. I am rounding up the parts to rebuild this starter and will be leaving this switch off. Whoever did this sawed off the battery cable post to make it work so I will be replacing it as well. Thanks everyone for your assistance with this as I wasnt familiar with the model B Starters.
