07-29-2013, 06:07 AM | #1 |
39 coupe new headlining fixing round the windows .
hi guys ...my 39 coupe , I bought a complete lb.bonney interior kit many years ago for the 39 ,its now ready to be fitted but I,v always had a mental block about fitting the headlining myself (the rest of it no problem) so I,v got a local trimmer who works with mostly coachbuilt English cars ..lagonda ..rolls bently etc and is not familiar with our fords , he seems to think the rear window and side windows need to be out of the car to attach the lining around the windows ,I,v got them in with weatherproofing sealer etc and really reluctant to remove them , I,v read the lbb instructions and they don't mention windows out only the mouldings removed ,if the windows are in how is the cloth attached? is it glue only? the rear window hasn't got a ridge like the sides it is flat and looks a bit difficult to attach cloth to , many thanks , cheers jim.
07-29-2013, 08:17 AM | #2 |
Re: 39 coupe new headlining fixing round the windows .
The rear windows as well as the rear - side windows do need to be removed to install the liner.
The cloth folds (and glued) in to the opening where the windows were.
07-29-2013, 08:24 AM | #3 |
If you are careful with the glue you can install the headliner without removing the windows.
07-30-2013, 03:26 AM | #4 |
thanks guys ,I don't really know which route to take ,to remove the windows will be a messy difficult job as its well sealed with goo,and the rubbers will be wrecked which means shipping again from u.s ,anyway my trimmer said he will pop over to have another look to try to find find an alternative way ,thanks again , cheers jim.
07-30-2013, 08:26 AM | #5 |
Kube and TJ are correct. I installed my 40 Ford coupe LB interior headliner with the glass in the car. Be sure and make nice 45 degree angle folds on the trim as shown in the LB instructions. Also be sure and allow enough headliner material for the visor brackets to screw into place. Click on photo to enlarge. BE SURE TO READ ALL OF THIS.
http://fordbarn.com/forum/showthread...ll+lb+interior Last edited by 19Fordy; 07-30-2013 at 08:51 AM. |
07-30-2013, 10:24 AM | #6 |
07-30-2013, 10:45 AM | #7 |
I am not a professional installer and this is the only one I have ever done back in 1988. If I can do it, I am sure your guy can also. If you can install it in an air conditioned shop it will be much easier. The key is to stay calm, read the directions over and over until you really understand and can get a "feel" of the process. Remember to install the dome light wire FIRST and don't cut any material until after you have finished the install. I ended up doing the entire interior including the seats. My wife sewed up new burlap pockets for the springs. The entire kit cost $550 from LB when I bought it in the early 70's. Make sure you keep your hands CLEAN. All the best. I am sure you will be successful.
07-30-2013, 05:40 PM | #8 |
MEMBER EMERITUS
Make sure your wipers are operating correctly BEFORE installing your headlining.
07-31-2013, 09:36 AM | #9 |
thanks swoop ,I have thought of that but as the engine is not running at the moment I put a thread on the barn a while ago and with advice and was told a vacuum(hoover) with the end covered in duck tape and a small hole with the rubber hose pushed in and turn the hoover on , havnt tried it yet ,just busy,failing that I,ll get the trimmer to fix the front over the wiper motor so I can lift up that portion , not ideal I know , thanks again. cheers jim.
07-31-2013, 11:19 AM | #10 | |
07-31-2013, 11:29 AM | #11 |
Kind of related... my coupe had a L-B interior installed just before I bought it 3 years ago. I have been thinking about replacing some of the delaminating glass.... but worry about how hard it would be with the new headliner... if it was possible without making a mess of things. My glass isn't terrible, kind of gives it that "patina".... so can't decide whether to take it on or not.
07-31-2013, 11:41 AM | #12 |
My view is: Unless it's really bad and you really can't stand how it now looks, leave it alone.
In this day and age, patina is an attribute. |
