07-25-2013, 01:58 PM | #1 |
Alternative brake light switch
Anybody know of a modern brake light switch that can be used on a 31 A? The repo's that I have doesn't seem to work.
07-25-2013, 02:06 PM | #2 |
Re: Alternative brake light switch
try A & L parts ....he has one that works like the original..check the vendors section..good luck
07-25-2013, 03:00 PM | #3 |
I'll second A & L. They don't have a web site but their phone
number is 860-693-0112. Bob |
07-25-2013, 04:36 PM | #4 |
Remember those spring loaded, arm type switches used under the floorboards on old Chevys. The arm just goes above the brake pedal. Somebody? maybe Mac's, listed them in their hot rod section. Bill W.
(The existing wires should reach O.K. & it just screws to the bottom of the floorboard with 2 wood screws. The switch arm "might" have to be bent a little, but it bends easy, without breaking! I know a man that put one for his clutch pedal to operate a little buzzer, so he "knew" when he was ridin' the clutch!)
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 07-25-2013 at 04:56 PM. |
07-25-2013, 06:07 PM | #5 |
The A & L one has a bronze bushing, so it does not stick or bind.........it works the best of any repro............
07-25-2013, 06:47 PM | #6 |
Hugh |
07-25-2013, 07:57 PM | #7 |
Go to a NAPA store and ask to see their catalog with brake light switches.
There are a whole lot of switches to check out. JB |
07-25-2013, 08:10 PM | #8 |
Do a search . A lot of info . I put a 29 switch on my 31 s/w . The 31 repro. I bought was junk . 31 switch caused me a lot of grief .
07-25-2013, 09:06 PM | #9 |
Catterpiller fork lift has A stop light switch that would work, in fact it Is the same switch that is used on a 49 to 54 chev. Maybe others.
07-26-2013, 11:48 AM | #10 |
Here's the PDF for A&L Parts,
http://www.scvcma.org/documents/bull...talog-2012.pdf
Mike Stitt "A business that make nothing but money is a poor business." -Henry Ford |
