07-15-2013, 11:20 AM | #1 |
32 33 34 ignition switch or column drop
City:
Waldorf
State:
Md
I'm looking for an ignition switch w/ key for my 34 fordor. I would also be interested if its the whole column drop w/ the key broken inside the switch.
07-15-2013, 01:55 PM | #2 |
Re: 32 33 34 ignition switch or column drop
The ignition switch is a square sheetmetal box with a phenolic back that is attached to the back of the drop with screws. This switch box has internal contacts and is turned on/off by the toggle lever at the front of the drop. The lock cylinder locks and unlocks the column and toggle lever. The lock cylinder is not an ignition switch.
07-16-2013, 02:43 PM | #3 |
