Old 07-11-2013, 11:40 AM   #1
duffer
duffer's Avatar
Default Brake question
What adjustment needs to be made if my brake pedal seems to go too far to the floor? Pads are ok . And the car pulls to the right when i brake.
duffer is offline   Reply With Quote
Old 07-11-2013, 12:09 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Brake question
Get yourself a good repair manual [ like Les Andrews or others]. These brakes are not like hydraulic brakes, these brakes have several adjustments and everything leading up to the adjustments has to be right before they will work correctly. To stop the pulling until you can really fix the brakes, try tightening the left adjuster a bit until the pull stops. Depending on what or which wheel is causing the pull will determine whether to tighten the front or rear.
