Old 07-07-2013, 08:42 AM   #1
39portlander
39portlander's Avatar
Default Rear shock & anti-sway kit for 39 Peekup
Would like some input on the Drake R shock/anti-sway bar kit if you have installed it on your vehicle. Looking to add to my 39 P/U, thanks. Scott
39portlander is offline   Reply With Quote
Old 07-07-2013, 09:28 AM   #2
mike42
mike42's Avatar
Default Re: Rear shock & anti-sway kit for 39 Peekup
39....I can't tell you about a pickup, but I did put in the front shock conversion kit and it really works great ! Big difference in ride and handling. My rears already had the shock kit installed when I got it. I bought my front kit from Yogi's for $ 160.
Mike
mike42 is offline   Reply With Quote
Old 07-07-2013, 09:40 AM   #3
Marv
Marv's Avatar
I bought my stabilizer and setup from Chassis Engineering for my 39 Ford sedan and i realy like it. I bought front an rear stabilizers. It should be the same for your truck as my car.
Marv is offline   Reply With Quote
Old 07-07-2013, 09:52 AM   #4
Papadale1
Papadale1's Avatar
Do you have the website for the Chassis Engineering/ Please?
Papadale1 is offline   Reply With Quote
Old 07-07-2013, 10:13 AM   #5
mike42
mike42's Avatar
Chassis has none in stock and that's why I bought form Yogi's. They are the retailer for Chassis. That was 3 weeks ago, but maybe more in stock now.
Mike
Old 07-07-2013, 10:17 AM   #6
Papadale1
Papadale1's Avatar
Yogi's web address?
Old 07-07-2013, 10:22 AM   #7
42merc
42merc's Avatar
I installed a Drake rear sway bar & shock kit on my '40 cpe with a stock rearend.
Quite laborious, fits right, works great.
The tailpipes will need reworking to clear the shocks.
Good kit.
42merc is offline   Reply With Quote
Old 07-07-2013, 10:32 AM   #8
felix37
felix37's Avatar
Go with Chassis Engineering! the fit is awesome! Chassis Engineering kits are truly bolt on kits, they utilize some of the factory holes in the chassis and then you use the already bolted on part for your template to drill the remaining holes. They also have really good instructions to help out the not so mechanically inclined.
I installed the front and rear shock/sway bar kit on my 37' sedan and it made a world of difference.
felix37 is offline   Reply With Quote
Old 07-07-2013, 04:46 PM   #9
39portlander
Thanks for the input, the kits I have seen are for 35-48 cars & 35-47 pickup for orig. rear end. I would guess made by one manufacture and reped./sold by others. Will check the yogi's
Old 07-07-2013, 04:54 PM   #10
mike42
mike42's Avatar
Yogisinc.com
Old 07-07-2013, 05:06 PM   #11
Marv
Marv's Avatar
Chassisengineering.com Phone 319-643-2645 & 319-643-2655 Marv
Old 07-07-2013, 05:22 PM   #12
Marv
Marv's Avatar
I misread your question. I bought a front swaybar kit from Chassis engineering for a original front end for my 39 Ford car but the rear kit was for a Ford 8" because i had changed the rear to get several different gear ratios and parts are easier to get. If you do want a front kit they are on ebay at gearheadworld. $142 and free shipping and are from Chassis Enginering. As far as i know they do not make a rear kit for an original Ford rearend.
