Old 06-17-2013, 05:56 AM   #1
roccaas
roccaas's Avatar
Default Spark Advance and Throttle Levers become "sticky"?
Saturday these two levers moved as they always have, Sunday they feel as of they've both been dipped in Elmer's Glue.
I see no binding at the distributor lever, no injury to any of the exposed connections, and the foot accelerator moves smoothly.
The car performs as it always has.
There is a real "heaviness" when pushing the levers up to the top of their arc. I'm guessing something in the steering shaft needs lubrication, or a piece has shifted, causing friction.
Weird!
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
Old 06-17-2013, 08:01 AM   #2
Logan
Logan's Avatar
Default Re: Spark Advance and Throttle Levers become "sticky"?
I would put some penetrating oil on the top of the rods and let that soak all the way down to the bottom. Sometimes things just get in a bind and need a little help.
Cowtown A's
Logan is offline   Reply With Quote
Old 06-17-2013, 10:45 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I lube them as Logan said and they have gotten much better than when I bought the car. The old potmetal bushing swell over the years, but I can't imagine feeling a change over a day or two.
Old 06-17-2013, 10:58 PM   #4
Dave in Boise
Dave in Boise's Avatar
similar thing happened to a buddy.. the column casing cracked allowing the upper part of the column case to rotate while the lower stayed put.. the levers bound up from the misalignment.. I know it's an extreme, but describes a worst case issue that was discovered in rebuilding his column..
Dave in Boise is offline   Reply With Quote
