Old 05-11-2013, 06:53 AM   #1
Max41
Default A little help please
I am assemblying my engine. The book I am using states to grease the gasket prior to install. The gasket is the cork oil pan gasket.....grease it, with what? Is it necessary to grease it? What type grease? Thanks
Max41 is offline   Reply With Quote
Old 05-11-2013, 07:14 AM   #2
Talkwrench
Talkwrench's Avatar
Default Re: A little help please
Pig fat.. Whale.. Perhaps.. A light film of wheel bearing grease is fine.. Makes the gasket easier to come apart. Permatex no.3 works ok.. Don't get to hung up about it.
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 05-11-2013, 07:34 AM   #3
Max41
Talkwrench, thanks. Pig fat, too late just finished ny bacon and egg sandwich!! Have a good weekend.
Old 05-11-2013, 08:33 AM   #4
bluardun
bluardun's Avatar
Basically there are 2 reasons to use grease on both sides of the gasket. First, as Talkwrench mentioned, it makes the removal of the gasket in the future easier. Verses a glue type gasket sealer. Second, the two metal surfaces it is sealing will contract and expand due to heat at different rates. This allows them to have a little movement and stay sealed.
Two suggestions: You might have to soak the cork gasket in warm water to get it fit as you desire. Second: Do NOT get greedy and over tighten the bolts. Find the tork speck for the bolt. You might go to VAN PELTS site to find the imformation you need.
have fun
bluardun is offline   Reply With Quote
Old 05-11-2013, 08:45 AM   #5
Max41
bluardun,
Thanks, great guidance. I have teat fit them already, alignment looks good. Torque specs in hand ready to go. Thanks again,
Max 41
Old 05-11-2013, 08:50 AM   #6
Shadetree
Shadetree's Avatar
When I was a young lad I would help my uncle work on cars and trucks. He was a mechanic in the army during WWII. He greased just about every gasket with chassis or bearing grease before installing it. I do the same.
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 05-11-2013, 09:04 AM   #7
41Fordor
41Fordor's Avatar
Van Pelts website has a lot of handy links:
http://www.vanpeltsales.com/FH_web/f...rvicelinks.htm
If you're rebuilding an 81A, I did this mod to the heads to help with overheating:
41Fordor is offline   Reply With Quote
Old 05-11-2013, 07:47 PM   #8
Talkwrench
Talkwrench's Avatar
Do it on carb gaskets too. When ever I change jets (this is on a 4 barrel) very lightly do the bowl gaskets even the metering block, the threads on the bolts etc .. Very lightly. I can take them off time and time again..
Old 05-11-2013, 09:15 PM   #9
4t8v8
Regular chassis grease on all paper or cork gaskets. Works great. Learned it from an old mechanic when I was just a pup. Now I'm the old mechanic - still doin' it.
4t8v8 is offline   Reply With Quote
