08-09-2010, 08:05 PM | #1 |
Best Tip?
Can you share the best Model A tip you have ever received?
Mine was to loosen the collar on the steering column and make sure the spark advance touches from side to side. |
08-09-2010, 08:48 PM | #2 |
Re: Best Tip?
When I bought my Phaeton, it had been stored for about 15 years. The clutch was rusted to the flywheel.
From the MAFCA Website Technical Tips... I got the following Fix for a stuck clutch - "I put the rear of the car on jackstands and left the rear wheels free to rotate. I then started the car in 1st gear and ran it a minute or two. I accelerated the car to about 20 mph on the jackstands. Then I depressed the clutch and hit the brake fast and hard. It broke loose! I engaged the clutch a few more times on the stands. When I put the car on the ground, the more I drove it the better the clutch worked. I sold the car to a friend of mine who put several thousand miles on the car with no problems. -- Chip Evans " It worked wonderfully. A few thousand miles later, I have never had any trouble out of that clutch. |
08-09-2010, 08:52 PM | #3 |
Re: Best Tip?
After painting a set of wheels make sure you use an exacto knife to shave out the paint from the wheel lug nut chamfers. This will prevent cracking the paint when tightening the lugnuts. Do not forget the spare only neds 3 chamfers shaved out!
Ken |
08-09-2010, 09:10 PM | #4 |
Re: Best Tip?
Buy an old 9/16" open end wrench to heat with torch, bend 60 degrees, and use it to hold the top nut under the bottom of the radiator. Don't mess up your new wrench trying these tool gymnastics.
Disconnect the battery when the car won't be run for a few days. Always drain the carb bowl after running the car (fuel shutoff). OK that one came from years of yard word with 2 cycle engines. Carry a cell phone and AAA card.
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die! |
08-09-2010, 09:17 PM | #5 |
Re: Best Tip?
coil polarity
08-09-2010, 10:45 PM | #6 |
Re: Best Tip?
Deron |
08-09-2010, 11:41 PM | #7 |
Re: Best Tip?
A good friend told me to loosen the lug nuts on the back wheel and drive around the block to get the rear brake drums to break loose if you do not have a puller and it does work.
08-10-2010, 12:30 AM | #8 | |
Re: Best Tip?
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com My restoration diary: http://dougbraun.com/blog |
08-10-2010, 12:36 AM | #9 |
Re: Best Tip?
An unrestored car is worth more in parts than a whole car.
08-10-2010, 12:49 AM | #10 |
Re: Best Tip?
plan on committing yourself entirely !
08-10-2010, 01:15 AM | #11 |
Re: Best Tip?
My favorite GENERAL tip: Rusty bolts won't break free?...apply heat with a small torch and cool with a wet rag. Most come right off afterwords!
08-10-2010, 07:22 AM | #12 |
Re: Best Tip?
Perhaps not the best, but the latest tip from "The Restorer", July/August, 2010.
I did have one of these incorrect springs in my parts inventory.
I know a lot of things; I just can't remember them all. 1928 CCPU 82-A 1931 Roadster 40-B Dlx (Canadian) |
08-10-2010, 07:43 AM | #13 | |
Re: Best Tip?
Doug
08-10-2010, 09:01 AM | #14 |
Re: Best Tip?
Welding a flat washer and nut to a broken stud for easy extraction of the broken stud/screw. This trick even worked on a broken screw that holds the Oil pump screen cover on the Model A oil pump..
And I learned of this tip years ago right here on the Fordbarn … |
08-10-2010, 09:46 AM | #15 |
Re: Best Tip?
Don't throw away the Bendix spring on the right in the photo above, give it to one of your Model T friends, he'll appreciate it.
08-10-2010, 09:54 AM | #16 |
Re: Best Tip?
08-10-2010, 10:02 AM | #17 |
Re: Best Tip?
Easy..."join a local Model A Club"....and start using Ford Barn.
Freddie (Memphis) "...an opinon on everything...an expert on nuthin'..." I'm still doin' the rhumba, Baby...I just can't seem to quit. If momma catches us doin' the rhumba....momma would just pitch a fit. I can't help myself....it's much bigger than me. If I were you I'd hang on to a rhumba man like me...! |
08-10-2010, 10:14 AM | #18 |
Re: Best Tip?
Marco's timing procedure. When I first got my car it was the first thing I had to learn.
08-10-2010, 10:20 AM | #19 |
Re: Best Tip?
Dont mess with boiling out an old radiator,get it recored.
08-10-2010, 10:26 AM | #20 |
Re: Best Tip?
Couple tips:
The removal of stuck head and manifold studs using heat and wax. See the thread: Head / Stud Removal Look to your Model A friends for help when you need it! |
