Where can I get one of those restricked fittings that goes into the side of the oil filter 49-8ba, this one is broken. 1/8 pipe into the can and take the flared 1/4 line fitting. Does anyone have a Dorman no? Thanks Walt
Walt, it is so easy to solder the hole closed in a standard fitting and then drill it with a 1/16" (.062") drill. Use a little muratic(sp) acid to clean the fitting.
I once tapped a fitting and used a carb jet for the restriction ---don't remember what the jet was from, but it got the job done
Walt.....I think I saw these for sale in C & G catalog.
'52 F-1, EAB flathead |
#8 | |
![]() Quote:
Walt it is a #1512 weather head fitting ![]() R |
Thanks R for that weather head part no. Walt
