Old 12-19-2013, 10:07 AM   #341
Pat/Ohio
Pat/Ohio's Avatar
Default Re: 2013 Moonshine Festival
Ken, I think of you and Barb daily. You have had a rough year. God Bless the both of you! Looking forward to see you guys in Gettysburg next June. Pat
Pat/Ohio is offline   Reply With Quote
Old 12-20-2013, 07:55 AM   #342
cushman man
cushman man's Avatar
Thanks,John for the pictures,It was a very good meet lots of old fords to enjoy.
cushman man is offline   Reply With Quote
Old 03-02-2014, 07:04 PM   #343
Buzoom
Hey Vic,
This is Mike Sydney from Homosassa. We met in Dawsonville. My 40 Flatty is acting like it is starving for gas when I get over 50mph. Carb seems to have plenty of fuel. Got any ideas? Fuel pump? Fuel line? Air leak?
Mike
Buzoom is offline   Reply With Quote
Old 03-03-2014, 07:22 AM   #344
Vic Piano
Vic Piano's Avatar
Hi Mike, Your description of the problem could be attributed to any and all of the things you mentioned however, I would check for any vacuum leaks and adequate fuel flow from the fuel pump to the carb. Also, check at idle, turn the air/fuel mixture screws one at a time to see if they produce any change in the engine idle. If they do not, that would most likely indicate a bad power valve. If everything with respect to fuel delivery is up to par and the carb adjustments do have an effect, I'd check the timing/distributor, etc. Without actually being there, it's tough to pin down the source(s) of the problem.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 03-03-2014, 11:46 AM   #345
Ken/Alabama
Ken/Alabama's Avatar
Originally Posted by Buzoom View Post
Hey Vic,
Mike
Have you tried slowly pulling out the choke to see if it goes away ? Also make sure your fuel pump isnt sucking air around the lid if you have a steel bowl fuel pump. If its a glass bowl make sure it isnt sucking air around the top of the glass bowl.
